Home > General > Fuse 30 & 37
kriswilson
Scotland 2007 Range Rover Vogue SE Supercharged Java Black
Fuse 30 & 37
Does anyone know what fuse F30 & F37 in the passanger footwell are meant to be?
F30 is meant to be blank according to the fuse panel but mine had a 30A fuse in it.
F37 is meant to have a 5A fuse in it according to the fuse panel but mines is empty.
Any ideas or thoughts welcome...
Post #45995 13th Jan 2011 8:47pm
oodathort
hi 30 is electronic damper control 37 is transfer box neutral when towing only insert fuse when towing vehicle Porsche Cayenne
RR Sport TD6
Porsche 911sc
AM vanquish
AM Db7
AM DB7
Lotus Esprit V8
Lotus esprit V8
Lotus esprit V8
Lotus esprit 2,2 turbo
lotus espirit 2lt turbo
lotus excel
escort 16 i
capri 2.8i
lotus sunbeem
jenson interceptor
land rover series 1
MGBGT
MG Roadster
Post #46001 13th Jan 2011 9:03pm
looked in the handbook [on rave] and F30 should have a 15 amp fuse and F37 should be empty
edit... the F37 is for the transfer box ecu which is only used for towing...
Post #46002 13th Jan 2011 9:04pm
kriswilson
Many thanks.
Have left 37 blank as instructed and have changed 30 to a 15.
Cant be that causing the battery to drain. Back to the drawing board.
Thanks again.
Kris
Post #46004 13th Jan 2011 9:09pm
