![]() | Home > Maintenance & Mods (L322) > Rocker cover gaskets... |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
Your not really meant to reuse gaskets and for the sake of the cost for two new ones if it was me i would just replace them again.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
I think I will get shot down here but bimmerforums claim the cheapest and ieasiest fix is to replace the washers on the bolts with slightly thicker steel washers to make the gasket compress more.... thoughts? Current stable:
Up to you what you do, be careful not to snap the bolts if they get overtightened just make sure use torque wrench.
Any ideas how many nm to tighten to? Current stable:
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Download RAVE as the torque setting is in there but it’s not that high. There are metal inserts that are fitted in the cover bolt seals to stop over tightening the covers.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1559 ![]() ![]() |
I assume you mean Newton metres, not nanometres? ![]() From RAVE: Left hand/Right hand camshaft covers nuts/bolts * 10 Nm 7 lbf.ft * Correct tightening sequence must be followed Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
