![]() | Home > Maintenance & Mods (L322) > EGR? |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I would take it out, checked for fatigue/intact, cleaned, ensure it closes and disable it. ______________________________
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Strangely, the problem has disappeared after a few uses of the beast.
If they’re working ok maybe go straight to disabling the EGRs. You could use some induction cleaner before hand. If you have an IID Tool it will indicate percentage open from memory. ______________________________
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 ![]() ![]() ![]() |
If you where to map out the egr's would you need to fit blanks? |
Just an update...
Further update.
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 214 ![]() ![]() ![]() |
Surely a tank full of super diesel woudnt cure it?..my iid tool says both egrs at 0% commanded. and position one is stuck at 5% and one stuck on 7% and the orange check engine light is on.car drives fine though but it's going in in Friday for new egr valves. 2009 Vogue SE Zermatt silver |
Well Shell Ultra makes claims for 'cleaning' the engine - that's why they charge 8p/l more for it.
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
When you use the IID tool does it show the actual position of the valves as 0% as when I use mine it registers the actual as 5% as a minimum but when I record them and pull the graphs they then show as low as 0% from this so not sure if they are only closing to max 5% or if this is the lowest figure the live value on the IID tool shows? Current 2007 TDV8 Vogue Buckingham Blue |
My iid tool says the position is 5% and 7%.Commanded says both are 0%.nothing changes no matter what speed I'm going and I have 2 egr fault codes and the orange check engine light is on 2009 Vogue SE Zermatt silver |
Mine both show 5% and commanded at 5%
