Home > In Car Electronics (L322) > USB AUX IN CD Changer Adapter for L322 Range Rover
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Has anybody fitted one of these to a 2004 Range Rover
https://www.ebay.co.uk/itm/USB-SD-MP3-AUX-....l4275.c10
If so does it work well?
Post #459626 4th Dec 2017 10:31pm
bobsin
2004 Range Rover Vogue Td6 Epsom Green
i did, i used the bmw one, gone android now, so it sits in it's box doing nothing. spliced into cd changer loom, to link phono level input to amp, easy job. it worked fine with usb stick and sd cards up to 4gb each. worked with steering wheel buttons ok for tracks and volume. regards, bob... (used in a 2004 td6, with dsp....)
Post #459636 5th Dec 2017 3:15am
matlandy
Thanks for your reply will definitely look at this as my CD changer is dead and a usb would make a perfect replacement.
Regards
Mat
Post #459640 5th Dec 2017 6:33am
bobsin
hi, you can have this one if you want, works fine, even displays track info on screen, see pic. make me an offer. as i said, i've gone android now, so do not use it.
Post #459787 6th Dec 2017 2:03am
