Home > Technical (L322) > Weird brake locking = akin to traction control kicking in |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
lov, drum brakes -( EPB on RR), can swell with moisture and lock the wheels . if it continues to happen, release the EPB a notch with adjustment wheel. |
3rd Dec 2017 6:16am |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
nino nino, it feels like the front is locking, but will check the rear drums. I did have rear drums lock on me once before as the shoes were U/S. I replaced the shoes and all was ok after that. Seems a stupid idea if you go through water and the hand brake shoes swell |
3rd Dec 2017 7:39am |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hiya,
3rd Dec 2017 9:13am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7806 |
Does the speedo work?
3rd Dec 2017 1:32pm |
Speedo works, I think my hand brake shoe is sticking on and since the rear wheel wont rotate it must send a signal to the ABS to lock the other wheels also. I won't know until I pull the wheel off and check the rear brakes. |
4th Dec 2017 12:39am |
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 |
It's a abs sensor front faulty scared living daylight out of me always in wet. |
4th Dec 2017 9:53am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I had the same thing after heavy rain and also car had been for it’s MOT so may have got upset with the wheels dangling down.
4th Dec 2017 7:11pm |
Holiday Chicken, may be dilectric grease is needed on these sensors to repel water? |
4th Dec 2017 11:49pm |
That could well be the answer or something along those lines
5th Dec 2017 12:25am |
I removed the rear wheels today and checked the brake shoes for binding, even removed the disc to check the condition of the shoes. All was ok. I then unplugged the front sensors at the connections and all was dry, I gave them a spray of electrical contact cleaner just for good measure. I disconnected the ABS ECU plug and gave that a spray with electrical contact cleaner also.
5th Dec 2017 1:45pm |
Have a search about regarding the ABS module as they can fail and give some strange problems |
5th Dec 2017 8:00pm |
Until you have substituted both left and right abs sensor and checked wiring you are looking too deep. I would also check you have not pushed too much copper grease down the hole it will attenuate a very small timing signal if not careful. |
12th Dec 2017 10:36am |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
http://www.fullfatrr.com/forum/topic40836.html
22nd Dec 2017 11:15pm |
