Home > Maintenance & Mods (L322) > Rear shocks
AshC
United Kingdom 2010 Range Rover Vogue TDV8 Alaska White
Rear shocks
Hi guys.
I’m after some advice. I need to replace my rear shocks as they are leaking quite bad.
I don’t quite a lot of towing and was wondering what people think of upgrading to beilsten shocks or if I should just stick with the standard?
Many Thanks
Post #458718 27th Nov 2017 7:36pm
Sandyt
Sure others with more knowledge will be along but from what I can determine rear shocks all leaks they may be ok
Post #458735 27th Nov 2017 9:04pm
Most rear shocks show signs of leakage as mentioned above... BUT, you have a 2010? If so, they have electronic shocks that cost a HUGE amount and rew only available from JLR (as far as I’m aware) so...... Maybe need to do a little more research sir Thumbs Up
Post #458746 27th Nov 2017 10:50pm
AshC
Someone else did say to me that it is usual for the rear shocks to weep but I wasn’t quite convinced. I have looked into the parts and they are only available from JLR at £333 each although you can by direct from Beilstein for similar money. As you can imagine I’d rather not spend that sort of money if it’s not necessary.
Post #458759 28th Nov 2017 6:41am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Are you sure you are looking at the correct year and part?
I only ask because I know the cost to replace both by a main dealer is about £1700 and I could be wrong but the 2010-12 units are different to the >2009 units.....have a look at Craig's post above yours.
I don;t know where you are in Essex but worth having a word with the guys at the Red Lion Service Centre in Orsett or Landmark in Southend. Both are independent LR specialists I am happy to give my car to.
Post #458795 28th Nov 2017 10:03am
AshC
Yeah it was Landmarque that gave me the price. They are the guys I normally use.
Post #458799 28th Nov 2017 10:19am
JackRegan
I remember being surprised at the price when the rears went on my 2011 SC. For a car that had only seen tarmac all it's life I was a little disappointed the originals only lasted 60k - 6yrs.
I had Bilstein fitted which cost £265 +VAT. making the total bill over £700 Shocked 2024 P550e Autobiography
2016MY TDV6 Autobiography - Gone
2011MY 5.0 SC Autobiography Black - Gone
2005 TD6 Vogue - Gone
Post #458800 28th Nov 2017 10:22am
