![]() | Home > Technical (L322) > Help! Cant stop alarm going off |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Is your bonnet ajar? The bonnet sensor sets it off.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
or just unplug it |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
Thanks guys, I did unplug it but it made no difference. I'm guessing that the battery is so deeply discharged that it wouldn't take a charge so the alarm was going off as if the battery had been disconnected.
AJ Johnny Member Since: 30 Sep 2017 Location: Bedfordshire Posts: 79 ![]() ![]() |
Mulcher, you said “halfway through charging the alarm went off”. Are you charging with the battery still connected? I was told years ago that traditional battery chargers can damage alternator diodes and other sensitive electronics. I don’t know this is fact and I’m not suggesting you have caused damage but disconnecting the battery might be a sensible precaution.
Charging a battery whilst still connected to the car does divide opinion sometimes. Last year I searched the forum and found that most owners seemed quite happy to charge in-situ with the CTEK charger.
The CTEK doesn't go as high as 16 V so I reckon I'm OK there. Did you find out what the cause of your battery drain was? 2006MY 4.2 SC BMW R1250 GSA Rallye TE Triumph Tiger 1050 (sold) 1979 Pontiac Trans Am (sold) |
Yes, fuse 12 hvac. Official wiring loom fixed it but now switching on the driver seat heater causes the loom relay to switch off dropping out the seat heater and hvac. The relay then re-engages restoring the hvac but not the heater. Indy is chasing an answer from LR tech. |
