Home > Maintenance & Mods (L322) > I am not happy with the FF today !!
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
So driving along with 3/4 a tank a fuel , looks a fuel gauge a minute later 1/4 of a tank !!!!!!
Goes to the garage put £30 of diesel in the gauge stays the same and so does the range.
Looks like is off to the specialists again, let hope its an easy fix.
Post #458346 23rd Nov 2017 7:10pm
GGDR
common fault - bad connectors in the fuel tank sender, search here loads on this
. Cheers, Greg
Post #458362 23rd Nov 2017 9:36pm
Baltic Blue
Gumball 3000,
Is your account profile up to date?
Have you upgraded to a 2011/12 4.4 tdV8 ?
Cheers
Post #458365 23rd Nov 2017 9:57pm
Gumball3000
It is now m8 lol
Post #458372 23rd Nov 2017 10:37pm
Baltic Blue
Cheers👍
As gonna says, well documented wiring problem.
Access under back seat.
B.B. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #458373 23rd Nov 2017 10:47pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
I had the same problem. All fixed now Very Happy What do I put here then?
Post #458380 23rd Nov 2017 11:59pm
Baltic Blue
Sorry Gumball,
I have been searching for the TSB, but can’t find it.
Someone with a better memory will know.
I remember it being about poorly crimped wires on a blue plastic connector and the solution is to just cut out the connector and solder the wires together.
Update this post when solved and I will add the details to my Fault log.
Cheers.
Post #458402 24th Nov 2017 10:40am
here's the info chaps,
''Fuel tank 'crimps' replaced (fuel gauge was reading all over the place) LTB00566v6 '' ... - .- -.
Post #458405 24th Nov 2017 10:46am
GGDR
http://www.fullfatrr.com/forum/topic41061....ltb00566v6 Cheers, Greg
Post #458423 24th Nov 2017 1:29pm
Gumball3000
Thanks guys , it seems that the wiring is going to be the issue.
Post #458435 24th Nov 2017 5:43pm
tj2k
United Kingdom 2011 Range Rover Vogue SE TDV8 Ipanema Sand
Fixed x 2
Mine's fixed - see various posts & pics here:
http://www.fullfatrr.com/forum/topic46574.html
Post #474453 31st Mar 2018 7:41pm
Gumball3000
Mine was fine after a new battery was fitted.
Post #474468 31st Mar 2018 11:56pm
