Home > Technical (L322) > Air suspension: Compressor exhaust valve removal
Landrover Mad
2003 Range Rover Vogue Td6 Buckingham Blue
Guys,
After reading some of the air suspension posts I went to remove the air suspension compressor exhaust valve/filter. Mine seemed to be quite tight, can someone who has changed one advise me does it screw out or pull out - and did you have to use pliers?
Thanks,
Stephen
Post #45641 11th Jan 2011 11:24pm
oodathort
The air pipe fittings have a ring round them where the pipe enters the fitting this ring has to be pushed towards the fitting to enable the pipe to be pulled out in other words push the ring pull the pipe Porsche Cayenne
RR Sport TD6
Porsche 911sc
AM vanquish
AM Db7
AM DB7
Lotus Esprit V8
Lotus esprit V8
Lotus esprit V8
Lotus esprit 2,2 turbo
lotus espirit 2lt turbo
lotus excel
escort 16 i
capri 2.8i
lotus sunbeem
jenson interceptor
land rover series 1
MGBGT
MG Roadster
Post #45649 12th Jan 2011 6:53am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Is it possible to post pics? As this is something I'd like to do....
Post #45650 12th Jan 2011 7:54am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
That's what she said... Rolling with laughter
No seriously though, good info, thanks! Thumbs Up
Post #45679 12th Jan 2011 10:11am
Landrover Mad
Guys,
I don't mean the air pipe fittings which I know have to be pushed in before pulling the pipe out, I am talking about the brass coloured, thimble sized compressor exhaust valve.
How does it come out, unscrew or pull - anyone know?
Stephen
Post #45691 12th Jan 2011 10:39am
Some of the filters screw out and others are a press fit. Best to use something like a pair of water pump pliers and hold firmly whilst turning it anti-clockwise
Post #45744 12th Jan 2011 1:49pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Im not sure which model you have but the 06MY WSM says to press in a retaining pin and pull of exhaust. I can be anymore specific I'm afraid as that's all it says.
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #45808 12th Jan 2011 6:40pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
I think we're talking about the circled part in the picture:
I have tried to remove it too but I'm not sure it unscrews, it's that stuck...
Post #46051 14th Jan 2011 10:16am
From what I've been told some are threaded and some are a press fit.
Twisting it out anti-clockwise will remove it no matter which if the two it is
Post #46091 14th Jan 2011 6:00pm
lrdaft
Scotland 2011 Range Rover Vogue TDV8 Santorini Black
It just unscrews modified part has a hole in the centre of the filter 2011 4.4tdv8 vogue black with black
2005 autobiography supercharged in Auckland blue!
2005 supercharged now sold
2011evoque now sold
2007 tdv8 vogue se gone but not forgotten
rrsport 2.7 hse gone
4.4 autobiography 2004
Post #46104 14th Jan 2011 7:55pm
BrianC
my motor was in the garage today as it was saying suspension fault every time it went up or down
it still works ok but its slow , they told me the computer says brush core temp to high ? should i replace the whole compressor or a certain part?
Post #46153 15th Jan 2011 12:07pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
i would say your compressor is struggling, hence slow and overheating so yes new compressor time. 2004 black Vogue TD6
Post #46164 15th Jan 2011 1:51pm
