Home > In Car Electronics (L322) > Reversing camera replacement... |
Knightmare Member Since: 22 Jun 2015 Location: Kent Posts: 84 |
Ok, so limited success in terms of swapping the camera. I now have a picture, however it looks suspiciously like an NTSC/PAL issue now. See below:
17th Nov 2017 4:21pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I just used one of these https://www.ebay.co.uk/itm/For-BMW1-3-5-6-...0505.m3226
21st Nov 2017 12:14am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
When I fitted one to the TD6 (MY 2005) I initially got a PAL/NTSC camera. It didn't work and I had to get an NTSC only camera. It looks as if you may be having the same problem. John
21st Nov 2017 8:49am |
I know that you can change the camera input on the early non-touch screen cars with NavCoder (NTSC to PAL) I wonder if something like the IID Tool might not be able to do the same on the touch screen system?.... I never looked as I had NavCoder! Yesterday I couldn't spell Engineer... Today I are one!
21st Nov 2017 9:03am |
Thanks guys. Very frustrating as the seller of the after market camera states it is an NTSC camera. But maybe mine is the exception to the rule and needs a PAL camera...makes sense when looking at the video input diagnostic menu. Just annoying that even though the system will quite happily display both options when in diagnostic mode, you can't set it.
21st Nov 2017 10:17am |
You shouldn't have any trouble getting a PAL camera cheaply to try! the main bulk on the market are PAL, the difficulty is finding NTSC!
21st Nov 2017 12:36pm |
