Home > Maintenance & Mods (L322) > 2004 L322 head light bulb question.
MattyB1983
United Kingdom 2004 Range Rover Vogue SE Td6 Java Black
Hi chaps,
Just a quick one.... was there ever a difference in headlights between spec levels. Only reason I ask is I'm after changing my low beam head light bulbs. After some reading on here there's some saying my car would use a D1S type bulb but then others say it's actually a D2S that i would need.
Any ideas ???
Thanks, Matt.
Post #457978 20th Nov 2017 8:00pm
if you have the square type headlights with separate side/indicator then your xenon bulb is a D2S, if your headlights have the side and indicator integrated then its the D1S...
btw they are for dip and main... ... - .- -.
Post #457996 20th Nov 2017 10:14pm
MattyB1983
Thank you very much chap. Mine is the earlier version (pre06) with square head light and separate side light/indicator assembly. So I'll get some D2S ordered....
Thanks again.
Post #457998 20th Nov 2017 10:23pm
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
Thanks Stan, you have too answered my question, so mine is D2S. Thumbs Up Thumbs Up Late 2004 FFRR Vogue 3.0 TD6 Tonga Green
Previous cars
Series 3 V8 conversion
1989 V8 classic Vogue
1992 V8 Classic Vogue
1998 P38 DSE
Post #458022 21st Nov 2017 8:27am
