![]() | Home > Technical (L322) > Location of starter motor on 2004 td6 (sorted!) |
Paulus1978 Member Since: 09 Nov 2017 Location: Leicester Posts: 89 ![]() ![]() ![]() |
You sure your battery is in good health? Sounds like it might be flat to me. |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
righthand side of engine when viewed from the front. follow cable from battery to solenoid its about halfway down the block. Just about knockable! Mine was a blue one! |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Gold star to Paulus!
Agree about the battery. Replaced mine last year with a Varta silver dynamic (second one) fine until last week then the call from herself won't start, tryed jumping off the spare battery I keep ( well it is a landrover) still no good had to change battery at the roadside which was fun, in the dark on my own, then started first touch |
@ Flashman,
Some great advice.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
The main lead from the battery to starter motor corroded on my p38 so this year I changed all the main feeds with new cables as preventative maintenance its just what I do worth it in my opinion cable comes with all brackets and fixings and the charge at battery end - pig to replace though but worth it for me |
