2006 4.2 SC Intake Valve query | |
Hi all,
I’m looking at a 2006 SC. She’s a bit rough around the edges, but the interior seems reasonable and is priced accordigly. She needs two from air bags and the rear spindle bearings, and a bit of spray work, but is otherwise up together.
However, the Indy shop that looks after her has told me that some early 4.2 SC engines suffer from an intake valve issue that sounds, a bit, like a leaking hydraulic tappet and ticks for the first 30seconds after a cold start. They say this is caused by slight play on the intake valve seats and it goes away when the oil gets up there to take up that space. Apparently, the vehicle throws a code every time you start it from cold.
Now I’ve looked for this issue on the internet and I can’t find anything about it anywhere! Is it a real issue or not? Vehicle has 220,000km and has done it since the guy bought it 560,000km ago.
Would you shy away from the vehicle because of this? Price is $6500 and supercharged FFRR are hard to find up here. The next available one is the same year and priced at $15k
Thoughts please? “The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
