Home > Wheels & Tyres > Wheels spacers ?????
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
I am after a better look for my l322.
It is a 2011 model and has 20" wheels on it but they sit a bit narrow looking if you know what i mean.
Is it advisable to run spacers ? Or am i better getting some different wheels with a wider off set ?
Cheers
Paul
Post #456909 11th Nov 2017 3:01pm
i contemplated doing this on my old td6 a while back cos the rears seem to far in the wheel arch..
i posted here on the forum and the consensus was that it wasn't advisable..in the end i bought some RRS wheels which are an extra inch wider .. ... - .- -.
Post #456912 11th Nov 2017 3:31pm
fisha
I wouldn't recommend a plain spacer which simply goes between the wheel and the hub ... I really wouldn't like to lose any of the thread depth on the nut to stud join.
I think as long as you run spacers which are the hub centric ones, you would be ok. You don't seem to get them in anything less than 25mm depth due to them needing space to bolt properly onto the existing studs.
Trouble is that 25mm is quite a jump outwards too. You start to get to the look of it being too wide. I have toyed with the idea myself ( and even have the persmission from the boss ). But there have been other things to spend the money one .... like petrol ! Rolling with laughter V8 or else ...
Post #456925 11th Nov 2017 4:54pm
Gumball3000
I am always looking for some 22" rims , but its hard work getting some that havnt been welded or are a fortune.
Just thought some hubcentric spacers might be an option.
Post #456953 11th Nov 2017 7:42pm
aftermarket rims are a waste of time, they can't handle the FF's weight and the rubbish roads we have..
i would go for genuine land rover rims ,be it 22 or smaller...more cost but less hassle. ... - .- -.
Post #456958 11th Nov 2017 8:02pm
