Home > Technical (L322) > FBH : Is there a sequence I am missing ? |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hi - Can only suggest you try again tonight - something might be a bit reluctant to start again after a long period of inactivity.
6th Nov 2017 8:07am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 799 |
I reckon your battery is shagged
7th Nov 2017 5:35am |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 |
I set the Timed Climate for 5:50am and nothing happened. I turned all the heaters to max even the hot/cold dial beneath the outlets...
7th Nov 2017 7:36am |
7th Nov 2017 8:16am |
Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57 |
Muppet
7th Nov 2017 9:23am |
Thanks for the info on the key fob, the procedures are a little different on mine but everything seems ok. I tried it last night directly in the car ( no RCU ) and that didn't work either so I assume something more sinister...It has always been touch and go and last year I thought I had a fool proof way but now that doesn't work either.... I need more help than most...sorry !! |
7th Nov 2017 9:47am |
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 |
All of you have newer vehicles than me, so can I expect my 2004 Vogue to work, or not work, in the same way?
7th Nov 2017 11:18am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
there is no special sequence, you press the button on the remote and it either works or it doesn't, don't need to unlock the doors etc.
7th Nov 2017 4:25pm |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 |
Of course, the real reason the fbh's are so troublesome is the simple fact webasto are junk. There's a reason 99% of trucks use Eberspacher, and it isn't because of cost. That's the top and bottom of it. |
7th Nov 2017 5:43pm |
Having read the document that Zeppfish sent, ( very informative, thanks ) it appears that my battery in my RCU is showing low however I did go to the car and press it right next to it and got the green light, then a small hum from the heater and the blower turned on with a few lights on the dash. Went inside, waited 15 minutes and came out to a freezing car again...the blower was just blowing cold air, same results if I use the Climate control in the settings....
8th Nov 2017 7:30am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
I know you are going back to the dealer and his car is a bit earlier than yours but this post by jonnyboy54321 gives a very good insight on how the FBH works.
8th Nov 2017 8:26am |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
I believe the FBH locks out after three unsuccessful attempts to start it so not necessarily something wrong with it.
8th Nov 2017 4:32pm |
tried yesterday with the remote ( new battery and made the right flashes ) but freezing when I got in....Last night I used the internal Climate Control and it worked this morning, nice toasty car, no defrosting etc... So it does work but intermittently, all cockpit settings were the same but this time it kicked in....weird !! I need more help than most...sorry !! |
28th Nov 2017 7:05am |
if the red light is flashing it probably needs pairing again with the module in the car. it should come o with the orangey/greeny light and then switch to green when it has registered the signal.
28th Nov 2017 8:42am |
