Home > Duckworth Parts > Lower tailgate cables
Wurzel
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Hi Dan - please can i have a price on a pair of l322 lower tailgate cables? I see from an old post there may also be a damping kit option?
Thanks!
Post #456386 6th Nov 2017 9:08pm
duckworthparts
Site Sponsor
Hi
Damper kit £65.00inc vat
or pair of two cables £43.00inc vat posted.
Cheers
Dan You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #456462 7th Nov 2017 2:41pm
Wurzel
Thank you - does the damper kit negate the need for / include the cables or is it in addition? Not seen one before..!
Post #456477 7th Nov 2017 6:36pm
duckworthparts
Site Sponsor
includes the cables You can paypal direct using - www.paypal.me/duckworthparts
Post #456565 8th Nov 2017 5:59pm
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
umm, that's a lot of money for a little bit of steel cable.
I went to my local rigger supplies company and they sent me down the block to get 4 swag-able electrical terminals. When I took them back it only took 5 minutes to cut 2 pieces of steel cable and swag the terminals on to make some custom tail gate stay cables. Total cost AU$15 (10 British pounds).
4 off Electrical Terminals, type 16-12 = 16mm2 cross section (4.5mm diameter) with M12 bolt hole.
2 off plastic covered steel cables (steel core = 4 to 4.5mm diameter (6 gauge); each 275mm (11") long.
Fitting took 10 minutes, even if a 5mm allen key is used instead of the correct torqs bit.
Bolt-to-Bolt length = 320
16-12 Terminals are a good fit to M12 bolts
And yes, I could have got boring old black, but blue is so cool....
bye 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #456736 10th Nov 2017 6:08am
