Home > Maintenance & Mods (L405) > 6k Service Intervals - something wrong? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Sounds like it may be a faulty (over sensitive) oil sensor |
4th Nov 2017 8:08am |
peanutbob Member Since: 02 Mar 2013 Location: UK Posts: 57 |
I have a similar situation in that at 7k miles a notification appeared to say service due in 500 miles. Spoke to the dealer who said that is too early, but bring the car in and we’ll take a look. So, it’s booked in on the 14th. Time wise it’s not due until March 2018
4th Nov 2017 7:14pm |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 |
I actually prefer to change the oil more frequently than 16k miles (especially for a car I plan to run for 5-6yrs), in my book that's just good practice. My concern is that the services are being called because of oil contamination (e.g. diesel), in which case any thinning of the oil could lead to premature engine wear. As I cant imagine LR really want their owners servicing cars every 6k miles (not great PR) I am concerned how bad the oil needs to be to trigger a service message. 2021 L405 Vogue D300
5th Nov 2017 6:47am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I think reduced maintenance cost as a marketing feature ie saving £400 a year, is amusing for a car when the purchase cost is over £100,000. ______________________________
5th Nov 2017 8:15pm |
Back from the dealer today. Vehicle didn’t need an oil change, so they altered the software on the service module and said oil dilution rate was 6.1.
14th Nov 2017 5:42pm |
I spoke with the master tech the other day. He said due to these Euro6 engines they are having issues with DPF regeneration cycles not completing during short trips. Was happens is extra diesel is injected on the exhaust cycle to try and burn off the DPF, if the engine is shutdown mid-cycle then the diesel leaks down past the piston and into the sump. The oil sensor is set to trigger at about 6-7% dilution...which for me is every 6k miles. Can't say I am happy about it, I do 16k a year so not a small amount of mileage but the wife uses the car during the week for short runs (school and dog walks), at this rate I am having the car serviced every 4 months! 2021 L405 Vogue D300
16th Nov 2017 8:54am |
ADI Member Since: 13 Oct 2017 Location: South Yorkshire Posts: 70 |
Oil service required message this morning on Incontrol App and the service menu in the car.
28th Jan 2019 12:29pm |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 |
My L405 is a 2016 MY and is Euro 6.
28th Jan 2019 12:57pm |
Update
1st Feb 2019 1:26pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
At the dealer yesterday I was told they were starting to see turbos fail due to lack of lubrication from oil with excess diesel in it, caused as described by JamesD, so don't skimp on servicing if you get this from doing too many short runs... Only Range Rovers since 1988 |
1st Feb 2019 2:05pm |
1st Feb 2019 10:59pm |
Q86ARR Member Since: 28 Jul 2014 Location: Cambridge Posts: 60 |
6.1% Oil Dilution is the threshold to bring the service light on. Sounds like you do need a oil & filter change! Depending on warranty start date this could be covered under goodwill |
2nd Feb 2019 9:09pm |
Montys 4x4 Member Since: 23 Dec 2014 Location: Suffolk Posts: 70 |
Please have a look at my posts reference oil dilution and early oil service frequencies. There is a software fix JLR have available for the 3.0 TDV6 and shame on the dealership you approached and their inability to approach JLR with your issues. Have a look at my post (link below).
4th Feb 2019 2:11pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Unless they have actually had the condition of the oil analysed they have absolutely no way of knowing the dilution level of the oil. They are simply relying on software on the car that is using an algorithm to determine the oil dilution level based on the number of successful and non successful dpf regenerations. IMO you might as well smell the oil to see how dilute it is. All the dealers seem to do is tweak the software now and again to try and make the situation seem better. Until the oil is regularly analysed nothing will change. What happens to the engines if indeed the oil dilution is actually excessive but the software doesn't indicate it? Would I buy a diesel car with a dpf.... not on your life. Interestingly it is not only LR who is having such problems. |
4th Feb 2019 2:29pm |
