![]() | Home > Maintenance & Mods (L322) > Transmission slipping when hot, 2006, L322 Td6 Vogue |
Lee Marsh Member Since: 21 Nov 2016 Location: Herts Posts: 44 ![]() ![]() ![]() |
Bought just over year ago, has done 140k, g/box changed by previous owner (not sure mileage), but think it's done somewhere between 30-50k since.
Could be hot oil in the transmission
Thanks Joe, nice one. I'll check into that perspective and report back.
Yes, common fault on the car, bottom of main radiator gets blocked up with stuff, then can't feed cooling water to the transmission oil cooler (tucked away under the alternator). New radiator normally resolves this, a fairly straight forward job. (see wiki)
Good one! I’m not getting any ‘Trans Overheat’ messages on display, (as discussed by RRPhil on various discussions). Possibly drain/flush rad and refill w/ coolant may possibly determine if lower rad is sludgeless?
£2.5k is about right |
Haha, yes imagine it's the difference between a g/box 'rebuild' that's had a hose down and new fluids - to one that's had all the valves, bands and splines etc tested/replaced as necessary. I've seen recon units for sale fitted for £1k!
Took it to Stephens Engineering in Ware, they've changed trans filter and oil (Dexron VI). Joe they say the oil cooler isn't water cooled, its air cooled? In that case radiator blockage cannot be occurring? (mine is Td6 5 spd). Stephens suggest the internal filter may just have been blocked? I find that strange, as doesn't explain why starts slipping when in heavy traffic? - and why would a 'blocked filter', be any more restricted in dense traffic, than under load when the revs pick up on open road? Operating temperature criteria would seem the main variable... However no temp warnings triggered at any time on dash display. Stephens said the oil smelled but there was no significant debris in the sump (they've 40 yrs on auto boxes, thats all they do). I'm told the fully synthetic Dexron VI will lower operating temp by as much as 10 degrees, hoping this along with increased flow from newly replaced filter will be enough. Am thankful it's driving ok but wary of getting stuck in traffic, in case starts slipping again. ... Surprised to learn the transmission is air cooled - doesn't right, and needs further investigates me thinks Last edited by Lee Marsh on 5th Nov 2017 12:38pm. Edited 2 times in total |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
I think I would be looking elsewhere for my servicing etc.
Have to say, it surprised me as this company (Stephens Engineering, Ware, Herts) has been recommended on these forums by members. The next obvious question it raises is, did they even change the oil and filter?
It's done less than 3,000 mls in last year, maybe that's a lot? If I'm going long distances I use a different car. And besides even it had half the mileage, it wouldn't any different a scenario. It also doesn't therefore suggest anyone should spend willy nilly, without properly identifying what's the cause.
We are trying to help Lee so be cool! |
Ok apologies to Clive if I jumped the gun and misinterpreted his comments. They are expensive cars to run, of that there's no getting round. I'm sure the OEM vs motor factor debate will rattle on and is as varied as the parts themselves. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2274 ![]() ![]() ![]() |
If its worth anything mine has done 150k and is 10 years old I have put 90k on in 3and a bit years and tend to over service that is preventative maintenance. There is a wealth of knowledge on here especially common faults I have been caught a couple of times but usually I am in front of the curve so as to speak and replace bits that should be about to or could fail - I have run these for years and they are reliable if you look after them my take would be change the rad and pipework to get the gearbox oil down to s decent temp - its not money wasted its money invested and takes a potential worry away
