Home > Technical (L322) > Battery flat!
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Battery flat!
Went out yesterday morning to start it and click! No start great! I used it the night before, surly the first cold night this season didnt kill my battery? I fitted a new one around 6 months ago, it was a Varta one but never did seem to crank quite the same as before. How do I test to see if it’s a faulty battery? 2004 RR 4.4 V8 Autobiography
Post #455664 30th Oct 2017 5:49am
one conclusive way is to do a drop test on it, most garages can do this... ... - .- -.
Post #455666 30th Oct 2017 6:09am
PaulM
What’s a drop test Stan? 2004 RR 4.4 V8 Autobiography
Post #455967 2nd Nov 2017 7:27pm
it simulates a total drain on the battery, ie all the lights on , heater on etc... ... - .- -.
Post #455973 2nd Nov 2017 8:43pm
PaulM
Ok well don’t think that’s what they did at Halfords.
Not been having much luck really. Called RAC out who said battery was too flat to test, but put a little charge i it to get me started. He said that the battery is not accepting a full charge, alternator was charging but only 33amps was going in instead of 60amps. I called the batterymegastore who I bought it from and he said my warranty was void because my battery was allowed to go flat. He told me to agm boost charge it then put it on normal till it reaches 13.5v but it never went past 12.28 in 24hrs.
I then took it to Halfords who tested it and it showed “good. Recharge” but cranking amps were down 682 of 920 and it didn’t start very well. Halfords said the battery was faulty, same as what the RAC had said previous day. I called up the batterymegastore online again and they said it’s not faulty because the Halfords test shows it as good and I need to recharge it. They said they would test it for me at a cost of £20! You can imagine my answer to that!!! 2004 RR 4.4 V8 Autobiography
Post #455991 3rd Nov 2017 6:04am
I think the drop test isn't nearly as dramatic as it sounds, they just connect it up to a small machine & read the display.
You either need to pursue Battery Megastore or take it on the chin & buy a new one from somewhere else.......
Maybe agree criteria with then beforehand ? You'll pay the £20, but if CCA is showing less than say 80%, they refund it & replace the battery ?
I had a very good experience with Euro Car Parts - competitive price & when the Bosch battery packed up some 3 years later, they tested & replaced it without a quibble Thumbs Up
Post #455994 3rd Nov 2017 8:39am
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
Just to barge in with a question, in the shed I've got one of those old Frankenstein-type devices. What may be asbestos sheets hold two handles with points on the other end, connected by some springy strip metal with a meter in the middle.
You poke this at the battery terminals and the meter reads red or green through the smoke. Shocked
Are these things any use nowadays as battery test devices? Should I prize it or put it on ebay? Old 110 2.3 Petrol ???? - ????
Old 110 200tdi ???? - 2004
1996 Discovery 300tdi 2004 - 2015 met fiery end being welded
2004 JEEP Grand Cherokee 2015 - 2017
2004 L322 Td6 2017 -
Post #456016 3rd Nov 2017 1:29pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
That's Censored , the battery wasn't "allowed" to go flat, it went flat on it's own and couldn't be stopped.
It only has one job to do, hold charge, which it has failed to do.
That's like buying a new car that breaks down the the dealer saying they wouldn't fix it because you allowed it to break down.
I'd be back to them lickety split and insist it be sorted under warranty.
Post #456021 3rd Nov 2017 2:17pm
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
PaulM ive had same issues before with batterymegastore bunch of clowns there if it helps ive just got a 5year gaurentee bosch battery 920 cold cranking amps and i spins my td6 over in the blink of a eye and was a fair price i think at £160 with vat
Post #456499 7th Nov 2017 8:14pm
holidaychicken
In response to hamlet as my quote was apparently unnecessary!!!
I agree, if the RAC says its faulty then I would class that as an independent verification of it being faulty.
Did you pay via credit card as they will cover it for you or failing that trading standards.
I bought my Bosch from eurocarparts on eBay as it was cheaper to buy on eBay and then collect from my local store. It’s the biggest Bosch that will fit in and has been on for a few years now and I only drive my FF every two weeks and it cranks like a bastard 😬
Think this is the one and can’t recall if you have done a battery drain test
https://rover.ebay.com/rover/0/0/0?mpre=ht...2267712456
Post #456505 7th Nov 2017 9:09pm
PaulM
I bought it on eBay back in March via Paypal so nothing I can do ref money back. I called trading standards/consumer rights which is ran by Citizens advise who told me a bunch of legal stuff to say which I had already done on the phone while I was being polite to battery megs store, then I just lost my rag a little and told them what I thought of their bullshit warranty. So basically there’s not a lot I can, I told them on the phone I would be in touch with trading standards and she said do what I need to but they wouldn’t do anything unless I paid £20 😡. I also told them I would be on lots of forums explaining what a dishonourable company they are, again age said up to me! I said any company with honour would just sort the issue out. 2004 RR 4.4 V8 Autobiography
Post #456774 10th Nov 2017 11:56am
holidaychicken
is there nothing you can do via paypal to open a dispute or message paypal as the goods should be covered under guarantee surely
Post #456829 10th Nov 2017 6:07pm
This is an informative page on the subject
Regardless of where you buy (in the UK), 12 months guarantee under consumer law.
Proving that you / your car didn't kill the battery, another matter.
(was credit card used to purchase through paypal? ....) .
Post #456838 10th Nov 2017 7:55pm
Weegie
I believe that if the purchase is made through paypal then the protection on a credit card is void. Open to correction. It may depend on the bank and their T&Cs. John
GAP iiD BT
Post #456849 10th Nov 2017 8:36pm
holidaychicken
Small claims court is quite cheap I believe
Post #456874 11th Nov 2017 1:29am
