Home > Technical (L322) > Oil filter housing help M62 4.4L V8 Petrol
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Just changing the oil filter and there is no centre spindle in the housing, is this a problem? Normal? am I in trouble Big Cry Big Cry
Post #455937 2nd Nov 2017 11:00am
Clivefog
Did it come out with the old filter?
Post #455966 2nd Nov 2017 7:11pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
It should look like this.
Post #455968 2nd Nov 2017 7:31pm
holidaychicken
I think mine was like it for years, it was only when i did my vanos i decided to buy another housing after checking that it was still present in the new one off ebay and then just removed the tower from the new one and screwed into mine.
it is very common for them to come unscrewed when the filter housing lid is undone and then they get thrown out with the filter.
The two connections are shown and i think one feeds up through the centre and then the oil is taken back down out the port shown in the bottom of the housing i think so it should still be filtered. the black square is the drain valve which lets out the oil when you remove the filter and that comes out the connection shown between the two main feed pipes.
I think the tower just distributes the oil up the length of the filter rather than all at the bottom
Post #455982 2nd Nov 2017 11:08pm
nino_nino
I found this on the net:
A potential problem arises with your 2002-2004 MINI during a filter change when the plastic cage 'detaches' from the canister cover and gets pulled out with the oil filter, allowing the spring to pop free. If the technician is not familiar with the early filter setup - the plastic cage gets thrown out with the dirty oil filter. Without the spring and cage in the early canister, the filter fails to seal against the cover resulting in 'low oil pressure' warning light.
Since the canister cover is built differently for the 'cage version' vs. the later version, the filter will not seal properly without the cage, allowing unfiltered oil to circulate around the filter. Circulating unfiltered oil is NOT good for your engine... not to mention the low oil pressure.
Another problem arises if you should happen to purchase an early 'un-caged' oil filter. If you use this filter with the later 'uncaged' canister cover, the filter will collapse affecting filtration and oil pressure.
The solution...
If you find a loose spring with the oil filter without the plastic cage, MINI recommends replacing the entire Oil Filter Housing module with the newer style housing.
Make sure the new oil filter has the plastic cage 'built-in'. You will be safe with the factory filter (NME1050 ) or the MANN filter (NME1056 ).
Nino Thumbs Up
Post #456015 3rd Nov 2017 1:20pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I've got a spare oil filter housing if you need one. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #456106 4th Nov 2017 10:52am
ohuntsman
Hello, thank you all for your replies!
Holidaychicken that is exactly how mine looks ( I did check the filter as I thought that I could have pulled it out - someone else must have)
Zebedee does your's have the centre column in it? If so how much are you looking for for it please?
Post #456149 4th Nov 2017 4:16pm
Zebedee
Hi - Yes, it's got the centre column. Does £28 including postage sound reasonable? PM me if you're interested. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #456325 6th Nov 2017 9:04am
holidaychicken
BUY IT ! That’s half what I paid
Post #456418 7th Nov 2017 1:30am
ohuntsman
Changed the oil again today and fitted this - thank you David - she's pulling like a train again!! Thumbs Up
Post #461870 22nd Dec 2017 8:49pm
holidaychicken
Nice easy fix Thumbs Up
Post #461877 22nd Dec 2017 9:12pm
RupertRR
England 2002 Range Rover HSE 4.4 V8 Giverny Green
Just to add my two-pence-worth if I may, I did an oil and filter change last week in my fatty - (M62 4.4 petrol) and every time I started up from cold afterwards the oil pressure warning light stayed on for a couple of seconds before extinguishing. The oil level was bang on the maximum mark on the dipstick (as it always is) and before the oil change the oil light had always extinguished immediately on startup.
I did some research on this forum and a BMW forum and decided the problem could be the oil filter not being seated properly, and so not pressing down on the drain "button" at the bottom of the oil filter housing. When you remove the filter it releases this "button" and allows the oil to drain away. I removed the filter again and found it was twisted. Presumably as the cap was screwed on it had rotated the filter, twisting it in a corkscrew. I did a bit of measuring to see how far down the filter must sit to press in the drain "button", thus sealing the drain hole, and put a new filter in the housing, tapping it down gently to the depth I had measured, before screwing the cap back on. That resolved the problem.
I assume the problem was that the oil filter was not seated low enough down, so wasn't pressing on the drain "button" allowing the oil to drain back when I switched the engine off, so on startup the oil pump had to refill the filter housing every time I started the engine before the oil pressure got to where it should be. Everything is fine now and I don't have to convince my wife I need an engine rebuild.
This may all be complete tosh to anyone who knows better, but it worked for me.
Happy Christmas.
Post #462098 24th Dec 2017 7:10pm
holidaychicken
That is correct, i always make sure the filter is seated in the bottom of the housing before screwing the cap on and i only use OEM filters.
i always lubricate the top of the filter where the cap goes in so it is less likely to twist when the cap pushes into the top of the filter as it screws up tight.
Post #462125 24th Dec 2017 9:43pm
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
This reminds me of what the mechanic at the LR dealer dound ( and showed me ) back in 2013 whenmy 4.4 Petrol was in for a service.
That very filter was installed a year before by the same mechanic in the same dealer, sp proper LR parts.
The filter disintergrated while being removed so no remains in the oil circuit, but still....
You just don‘t want to see such things...
Regards
Heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #462147 25th Dec 2017 11:14am
holidaychicken
Shocked
Post #462154 25th Dec 2017 12:37pm
