![]() | Home > Technical (L322) > Aux Heater Question |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
Same here regarding heater not listed on the computer, and I'm still baffled as to whether it has one or not? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
I enabled it on my td6 with a diag tool and it appeared in the menu.
Here we go....had to enable Aux Heat as well as Aux Cooling...
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 ![]() ![]() ![]() |
So I have read the post and it mentioned that you need to have a change over value fitted also.
All diesels had the heater as standard..... I assume you have a td6 as you have not filled in your car profile yet.
Yes I have the the TD6 model and it has aux vent displayed on the screen on the dash board. |
Mine was like that. It will only blow the air from outside in, to �vent� the hot air out in the summer so the car interior is no hotter than outside....or thereabouts.
Think this was the post I was looking for. Thought I�d posted more than the thread above....
