![]() | Home > My Range Rover > Hi, possible new owner. |
Hitby Member Since: 20 Oct 2017 Location: Middlesbrough Posts: 47 ![]() ![]() ![]() |
Good evening all,
themule Member Since: 03 May 2016 Location: Yorkshire Posts: 126 ![]() ![]() ![]() |
JFDI |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Thanks guys. You’ve all done a marvellous job. I’m going to head over on Saturday and do the deal assuming it’s not sold by then. Presumably I’ll be back relatively quickly for advice |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
No need to be nervous just find a good local indy and give him direct access to your bank account and it will be fine |
Well, I went for a test drive and took it to a friends garage to look at. It needed brake pipes (he said he’d have failed it), a few suspension bits, side steps were rotten and the rear tailgate was worse that I’d thought, the rust was through the paint. Not including 4 new tyres which it’d have needed shortly it needed about £1400-1500 spending on it to make it right. So, alas, there was no deal to be done. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Keep looking, the right one will come along eventually. I walked away from many before purchasing mine.
Thanks, they seem pretty thin on the ground up here in Middlesbrough but yep, the search continues 👍🏻 |
northernmonkey Member Since: 30 Jul 2017 Location: Teesside Posts: 14 ![]() ![]() ![]() |
If you do find one, I use pvh Land Rover in stokesley for all my FFRR needs, they have been there for about 30 years and always do me a great job at reasonable price. Keep looking, I had to go to Chelmsford for mine, but once you decide on the spec and colour you want, don’t let distance put you off! Just spent the morning cleaning mine and I still love it as much as the first time I drove it 2012 westminister Overfinch Obsidian Conversion |
Thanks,
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
I’m watching this with interest, good luck! |
Oh no, it's sold already |
Have a good look at it & take your time. 12 months warranty is good though. If you can get hold of the chassis No then you can do an HPI check, this would give you the current MOT status, but not as good as doing a full MOT check as this lists any previous failures & advisories.
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
Those look like Overfinch wheels. They can tend to crack at edges and then leak air. As well as having that "bling" or "pimped" look. I had same on mine but have gone back to "stock" rims. 19". I found someone off a well known online trading site. |
