![]() | Home > Maintenance & Mods (L322) > Front Drive Axle & Rear Differential DRAINING & FILL |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 354 ![]() ![]() ![]() |
6. Instal the FRONT Diff DRAIN PLUG back in - Tighten to 54Nm ( 40 ib.ft ) 7. Fill the FRONT Diff casing upto: 750ml ( you will know when shes full as it will start to come back out of the filler plus DO NOT OVERFILL 8. Torque the Filler plug to: 35Nm Pic of my Front Diff below:
REAR DIFF Filling: NOTE: ENSURE you only have a OPEN Differential and NOT a ETM Differential - as the Fluids and fill quantities are very different A) OPEN REAR DIFFERENTIAL B) ELECTRONIC TORQUE MANAGED (ETM) REAR DIFFERENTIAL This only applies to version A: OPEN REAR DIFFERENTIAL 1. Remove the FILLER PLUG FIRST 2. Remove the DRAIN PLUG Next 3. Drain the Rear Diff fluid 4. USE A NEW DRAIN PLUG - see pic above 5. DRAIN PLUG - Tighten to 28Nm 6. Fill with the correct fluid see above - again ensure you DO NOT OVER FILL OR UNDER FILL - you will see it come out of the filler plus - Quantity should be: 1.14 liters 7. Insert the NEW Filler plug are tighten to 34Nm
Picture Below: THIS IS WHAT TO USE - TO FILL THE DIFFS UP - IT HOLDS FLUID - AND IT GOES IN 100% - NO SPILLS x IF YOU ARE GOING TO DO A JOB - DO IT 100% and Don't Mess Around - Perfection is key
Wipe all areas clean - check again in a few days time to ensure no leaks As this is such a simple job ( you may ask your wife to do it next time ) - I strongly suggest you do this every 20,000 miles on both the Front & Rear Diffs - although LR recommends the oil to be changed at 75,000 miles intervals - I am sure you would agree OIL never lasts that long and the cost and time to do such a simple job is a no brainier. ******IMPORTANT **** NEVER GET UNDER THE RANGIE WITHOUT Axel Stands supporting her - and set to Rangie to MAX off road Height - ENSURE YOU HAVE ENOUGH AXEL STANDS TO FULLY SUPPORT her if she decides to lower to access height - they can and they will one day - so be warned and be prepared - SAFETY FIRST ALWAYS I have ramps in the workshop or outside she goes onto Railway Sleepers which weigh a Tonne and worth every penny I hope this helps anyone . Last edited by EmiratesA380 on 23rd Oct 2017 10:29am. Edited 4 times in total |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
...one more - on the other post you mentioned LR copper washers but you've not mentioned these here. I take it this is for the Transfer Case?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
another great 'how to'...wiki'fied.. |
Hey Greg - ONLY THE TRANSFER CASE USES LR COPPER WASHERS Not The Front & Rear DIFF - on these just use PTFE Tape - They are a tight fit - DO NOT PUT TOO MUCH PTFE tape on - you just want a nice tight seal. again hope this helps you . |
Greg - On a Rangie ONLY USE Genuine LR parts - Bolts, nuts / threads / washers - never use third party items and such as hell not from Ebay - hell that would be bad !!!
Roger that.
That's a 14mm allen key right?
Tight777 Member Since: 26 Jan 2018 Location: Epping Posts: 88 ![]() ![]() ![]() |
Is it just me that can't see any pics? |
there are no pics..
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1550 ![]() ![]() |
Why?
I use Aviation Sealant No.3 (Non-Hardening). https://www.permatex.com/products/gasketin...nt-liquid/ Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
To add to Emirates 380's excellent post; I have a 2011 TDV8 4.4 and the rear diff is the electronic version. So it's a little bit different from the details above, specifically:
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 ![]() ![]() ![]() |
I have all the parts to change the front & Rear diff, and transfer case oils. However, I assumed I didn’t have the electronic version of Rear diff, but reading about the square drain plug (which Dan from Duckworths believes I have), I’m now wondering. Is there an easy way to find out which version of Rear diff you have without getting under the vehicle? Chris |
Chris get your VIN and go onto the topix website. In a few clicks you'll find your build sheet which should say.
