Home > General (L405) > 405 SDV8 same engine as 322 TDV8??
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Is the SDV8 basically the identical engine as the older TDV8 ?
...or more to the point, if it is basically the same, does it have the same oil leak fault into the 2nd turbo that requires the drain mod? ......and if so , why on earth didn't they fix it?!!??!?
Thanks.
Post #454811 21st Oct 2017 1:40pm
Baltic Blue
Sorry I can’t be precise, but if it helps you any, the MD technician who did the mod on mine told me that “early” L405’s suffer from the same problem, which sort of suggests that later models are modified in production.
Cheers
B.B. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #454816 21st Oct 2017 2:08pm
Fleagle_UK
mmmmm suspected so.
Cheers BB.
Anyone got the VIN range of the 405's that were still affected?
Post #454818 21st Oct 2017 2:12pm
Baltic Blue
If, and it is a big if, I was buying an L405 of any vintage, I wouldn’t sign anything or hand over a penny, until the dealer either modified it, or was able to demonstrate to my 100% satisfaction that it was already done.
You, more than most, are well aware of the DPF problems that can be had with unmodified 4.4 tdv8’s.
Cheers
B B. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #454824 21st Oct 2017 3:16pm
Yes the same old fault on both 322’s & 405’s!!! A friend has just had the mod done to his “63” 405... Pretty poor JLR...
Post #454833 21st Oct 2017 5:19pm
