![]() | Home > Maintenance & Mods (L405) > Headlight bulb changing L405 |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
It may not be the bulb, it could be the igniter. So a diagnosis is required but £90 does seem steep. |
vanquishspirit Member Since: 10 Feb 2012 Location: United Kingdom Posts: 131 ![]() ![]() |
Ah right, so the technician needs to plug his machine in then? I am beginning to fall out of love with Range Rovers! its just a light bulb , why does it have to involve a bloody computer diagnostic. Yes I see why, but do we really need this level of complexity? 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
If you can get to it, i would swap it over to the other side to confirm...but I'm not familiar with the 405. |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
Assuming you have the Diesel ? then its a case of undo the jubilee clamps from each of the air filter boxes behind each headlight then lift up and out and swap the bulbs left to right to diagnose , you still need small fingers and good glasses and a dry environment to do it though . |
thank you. I have given up and booked with another dealer who is not charging for a diagnostic. looks like he will be having a new order coming his way ! 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
