Home > Orders (L405) > SVAutobiography Dynamic vs Supercharged Autobiography
This topic is locked: you cannot edit posts or make replies.  Down to end
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Hi all
I’ve ordered my 18MY SVA and have noticed that whilst the power output is higher than on both 17MY and the ‘standard’ 18MY V8SC, they’re still quoting identical 0-60 times. Anybody know why? I can’t work it out?
Thanks
Post #454259 17th Oct 2017 8:37am
Phil.
There are increases of 7% BHP and 12% NM, probably too little difference to feel when driving. I’m guessing that all the extra options must weigh more if you spec the lot which you can and probably should on the SVA. Is the locking diff included as standard with the SVA, again adding a bit more weight? MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #454261 17th Oct 2017 9:29am
Autobiography
That must be it. Everything is either standard or NCO on the SVA so I’m ordering full spec.
Post #454264 17th Oct 2017 9:56am
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I've noticed you can't spec 20" wheels on an SVA. Is there any reasons why not (other than taste!). I have 20" off road wheels that I fit in the shooting season. Would they fit and SVA or are the brakes bigger?
Also, does the lower ride height mean that offroad is also commensurately lower? Or the same height?
Post #454268 17th Oct 2017 11:01am
Autobiography
Can't see any reason other than aesthetics - both wheels are 'exclusive' to SVA. The brakes are no different to the SDV8.
Post #454332 17th Oct 2017 7:58pm
This topic is locked: you cannot edit posts or make replies.  Back to top
