Home > Maintenance & Mods (L322) > Deployable steps
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Deployable steps
Anyone have ideas what the power output point they use as since coming back the steps don’t pop out or are they usually on a certain fuse number? Thanks _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #453978 13th Oct 2017 8:33pm
Power switch in roof panel (next to sunroof switch) or try a battery reset as the ECU may need resetting... Thumbs Up
Post #453984 13th Oct 2017 9:43pm
Scottyav
Tried a reset battery took leads off touch together then put back on an hour later still no joy, where’s the power supply from or fuse number you might know or would it go off any other possible feed? Thanks _____________________________________________________
Post #453991 13th Oct 2017 10:56pm
Scottyav
Working now woohoo
Steps no worky....
Press and hold the sidestep button on the ceiling, turn ignition on whilst holding button, hold for 15 seconds, turn off ignition and release the button
Sidesteps should now be programmed and work _____________________________________________________
Post #453993 13th Oct 2017 11:07pm
