Home > General > Choice of Diesel.... normal or premium
GavinBell
Romania 2012 Range Rover Westminster 4.4 V8 Santorini Black
This should be in L322 section - but imagine it might be of interest to everyone.
Does the choice of diesel - normal or super make any difference in a 4.4 TDV8? Does paying extra make a worthwhile difference? I know higher octane petrol makes the bike smoother and more efficient.
Out here - I will probably use the premium winter diesel as it copes with the odd extreme lows better.
Best
Gavin Series 2a LWB Hardtop - ex British Aerospace that was then used in an armed robbery! not by me!
2 door V8 1979 Range Rover
A slight Subaru blip..
110 County 200tdi
R reg 300 tdi Discovery Aviemore - gone to a local enthusiast to be resurrected in Transylvania
2003 TD5 Discovery2 - now sold
and the 2 wheeled Range Rover - BMW R 1150GSA
and finally the big lady of my dreams... 2012 Westminster - gives me a smile every morning
Post #453741 11th Oct 2017 4:30pm
emilio
Malta 2012 Range Rover Westminster TDV8 Orkney Grey
i use premium. bum dyno tells me i get more hp and torque out of premium
Post #453742 11th Oct 2017 4:42pm
always used asda fuel with no problems......(queue fuel brand debate.......again. Laughing ) ... - .- -.
Post #453750 11th Oct 2017 5:14pm
Baltic Blue
Normal or premium ??
The answer definitely changes as you move around Europe.
In the UK I honestly can’t tell any difference between supermarket diesel and Shell or BP fuel.
Move across to France and the difference is obvious
Cheap supermarket diesel causes significant more engine noise and reduced MPG..
I have also noticed significantly better MPG in Spain and Portugal when I avoid cheap supermarket fuel.
The debate will run for ever !!! G reg 2.5VM Vogue Portofino red 1991- 1999
Post #453761 11th Oct 2017 6:28pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
All effectively the same stuff to the same standard when it first leaves the refinery - the difference is down to the cetane improver and detergents added to make it "premium".
Post #453764 11th Oct 2017 6:50pm
GGDR
So Trimmels logic - and I don't disagree - you could put your own additive in cheaper fuel.
That would be an interesting test.
. Cheers, Greg
Post #453767 11th Oct 2017 7:09pm
GGDR
Sorry - Trommel. Cheers, Greg
Post #453768 11th Oct 2017 7:10pm
pld118
This 2014 thread might keep you occupied if you want to ponder the merits of premium fuel etc...
http://www.fullfatrr.com/forum/topic22856....p;start=60
Post #453769 11th Oct 2017 7:23pm
Chip fat does me Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #453776 11th Oct 2017 7:58pm
aneurysm1
2010 Range Rover Autobiography TDV8 Cairns Blue
It might be a local issue too. Close to me there is a morrisons fuel, I have only ever used it 3times in 3 different cars, and each time, shortly after I have had the 'water in fuel' warning come along.
And also, the Texaco closest to me always makes my Full Fat feel so much smoother, like silk.
Can't saying ever noted a difference from using any premium. However I regularly add the red ex dispel fuel cleaner, and that definately does make it feel smoother and gets me about another 50 miles out of a tank.
Post #453868 12th Oct 2017 7:30pm
Provarmint
England 2007 Range Rover SE TDV8 Buckingham Blue
Since buying my 3.6tdv8 L322 and having the egr valves replaced I've been using Shell V Power diesel, ran down to Cornwall and back last month and it ran very smooth. Since getting back and doing more short journeys it's still a pleasure to drive.
Post #453878 12th Oct 2017 8:27pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Mine seems to prefer Shell or Esso over Supermarket fuels, as did the D3 and D2 before that; not really sure why, as they should all meet the same standard.
There have also been a few horror stories over the years about fuel pump failures (not just L-R) after filling up at Tesco etc ... Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #453894 13th Oct 2017 4:24am
For me a Shell Fuel Card and the many Shell stations is the answer. Same quality fuel with inbuilt additives every time cannot harm. Thumbs Up
Post #453902 13th Oct 2017 7:29am
@mike [baltic blue] re france, i saw loads of police filling up at the e.leclerc pumps and considering the hard work they do ,the fuel cant be that bad..
an interesting article that makes a lot of sense,
https://www.regit.cars/car-news/is-superma...-car_65626 ... - .- -.
Post #453906 13th Oct 2017 7:41am
