Home > Maintenance & Mods (L322) > Is there a "How to...." for gearbox oil/filter on
gizze
I have searched and searched, can find it for every other gearbox, but not the 3.6 TDV8 with the 6 speed ZF 'box?
I know on the Mercs the transmission fluid had to be at 80ºc when measuring levels, using either diagnostic or an infa red thermometer on the transmission case itself.
Is there a dipstick on these etc.?
Cheers guys! Thumbs Up Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #453024 5th Oct 2017 9:12am
RRPhil
The fluid temperature should be at 40°C when the level is checked.
There’s no dipstick. It’s a combined filler/level plug on the right-hand side of the casing
Only use a genuine IBS Filtran filter/sump pan
Only use genuine ZF Lifeguard Fluid 6
It makes sense to replace the mechatronic connector sleeve at the same time as you're replacing the filter if yours still has the old orange seals on it
but be careful not to touch the electrical pins (ESD sensitive)
Be sure to lubricate the selector cable clamp bolt while you’re under there, to ensure that it can rotate in the lever
Phil
Post #453038 5th Oct 2017 11:28am
gizze
The man himself!! I feel honoured Phil. Very Happy
Seriously mate, thank you so much for that, really appreciated. Porsche 911 (996)
Post #453039 5th Oct 2017 11:32am
you cant get a better reply than that!.....nice one Phil Thumbs Up ... - .- -.
Post #453040 5th Oct 2017 11:40am
gizze
Is there a good place to buy the kit for the change?
I was thinking that maybe have a flush somewhere, but I would then want to change the filter, many say they don't 'need' to, but to me that seems absurd??
So I guess my thinking is, have the flush, then buy the new sump/filter and maybe 3-4 litres of the fluid to replace any I don't catch when dropping it again.
The chances of finding someone who flushes and does the filter seems slim to none.
Is there not a way to get push the fluid out of the TC?
On my 7 speed Merc I would undo the oil cooler return after changing the 5 litres you can get out that is not in the TC and that would then push out 2 litres of the dirty stuff, you would see it go from dirty and smelly to red again.
Then top up again with 2 litres of new fluid and start to fill and measure.
This would get around 95% of the fluid changed and you would have a new filter and seals etc.
My car is on 128k miles, the thought of leaving the old filter in sounds stupid to me, the thought of leaving 60% of old fluid in there sounds equally stupid. Am I worrying too much though? Porsche 911 (996)
Post #453064 5th Oct 2017 3:21pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
...I have the OE filter & correct ZF oil in the for sale section at the moment.
Post #453072 5th Oct 2017 4:51pm
RRPhil
ZF’s Technical Training Guide shows this photo :
which appears to show the pressurised fluid filler device inserted straight into the torque converter fluid circuit (i.e. the lock-up clutch ‘off’ or ‘release’ port) yet I’ve never seen any other reference showing this method being used, even in ZF’s own guides :
https://www.zf.com/corporate/en_de/afterma...ang_1.html
Curious Confused
Phil
Post #453073 5th Oct 2017 4:52pm
gizze
Hmmm? Very curious indeed!
JCW I will drop you a PM when I get home, I'm on my phone at the mo. Porsche 911 (996)
Post #453077 5th Oct 2017 5:11pm
fisha
Gizze, I plan on flushing mine next week if I get the time. I was planning on intercepting the cooler connectors by the radiator, ditching the output of the cooler and pumping in new oil back along the line to the box.
I plan on starting it up and running it through each of the gears for a short time and watching till I get clear oil out again. Then checking the levels again.
I'll do a flush first then come back and drop the filter later on. V8 or else ...
Post #453134 5th Oct 2017 10:26pm
Rangeyman
This may not be your model but is very similar and gives a good idea what is involved .
Post #453211 6th Oct 2017 10:11pm
