Home > Technical (L322) > Testing Air Con Fan (condenser) |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
This good 'ol boy does a good job of explaining it all
3rd Oct 2017 4:58pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I have been working on a TD6 2006 as it's immobilised but I got the ignition to turn on and we have been running various diagnostics and I noticed smoke pouring out from the front grille from the fan motor.
3rd Oct 2017 6:27pm |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Thanks for the link Joe, but as you say slightly different setup to the RR. The 3rd wire on the RR I am pretty sure is some sort of switching feed, so the motor probably gets 12v permanently and is then switched by a low voltage feed from the ECM. That is why just hooking it up to the battery doesn't do anything, or as HC observes just gives you a momentary twitch.
3rd Oct 2017 9:06pm |
You are right about the switch feed, but not so sure you are right about where it gets its info from (although what you say makes sense!).
3rd Oct 2017 9:35pm |
