Home > In Car Electronics (L322) > dab
standupking36
dab
evening is there anyway of upgrading our normal radio to dab? we have a 2005 td6 many thanks
Post #452646 1st Oct 2017 5:10pm
only an after market jobby, like 'pure'.... ... - .- -.
Post #452647 1st Oct 2017 5:13pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
I fitted the Pure Highway adapter in my p38 couple years ago now, the main unit is hidden in the dash and its just a small display about 2" square sit in a holder which is removable sits on the dash, not the cheapest option at the time but I liked the idea of the main unit hidden. hopefully I will be able to fit it in the next rr as I plan on taking with me I only ever listen to planet rock on dab or cd`s, think Alpine do a unit that look identical.
Post #452678 2nd Oct 2017 12:01am
Alpine EZ-DAB lets you change the display colour. I don't believe the Pure does. Got - 2017 SDV8 Autobiography in Loire Blue
Post #452706 2nd Oct 2017 12:04pm
gizze
But the Pure does have a hard wired FM cable which the Alpine doesn't.
If you travel around a lot this can be very handy. It allows you to override weaker pirate stations that can mess with the signal if you use the FM to hook up rather than the aux input. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #452711 2nd Oct 2017 12:50pm
^ The FM connection option is rubbish in my experience. Got - 2017 SDV8 Autobiography in Loire Blue
Post #452721 2nd Oct 2017 4:20pm
gizze
I quite like it. Haha.
I have a bluetooth adapter in my aux, and with a decent DAB aerial there is no need to have FM/AM at all, so being able to plug the DAB straight into the FM aerial and leave the Audx input free for bluetooth is a real bonus imho.
But only FM direct from the unit hardwired, FM signal is a waste of time. Porsche 911 (996)
Post #452727 2nd Oct 2017 4:40pm
standupking36
trouble is our's dont have an aux input!!!
Post #452751 2nd Oct 2017 6:32pm
gizze
The RR Autodab might be the best choice.
Do you have the screen?
This plugs in out the way and uses the RDS on your screen to control it using the steering wheel buttons etc.
The Pure Highway also uses FM also gives you in input for iphone etc. too.
There are newer version with bluetooth etc. but they are only FM transmitter rather than hard wired. Porsche 911 (996)
Post #452762 2nd Oct 2017 7:30pm
standupking36
hi, yes it has a touch screen, its a 2005 td6 if that helps
Post #452782 2nd Oct 2017 8:52pm
standupking36
what do you mean plug in?
Post #452785 2nd Oct 2017 9:01pm
gizze
Have a look at this....
http://www.bassjunkies.com/car-audio-dab/d...ab-dab-lr1
It plug in the rear, into your BM54 in the boot space, then you use the radio screen to see the stations etc and the steering wheel controls to control it. You could put the aerial in the rear window for a really easy install.
Edit: 2005?
Is that the BMW nav or the later Denso Touchscreen? Porsche 911 (996)
Post #452788 2nd Oct 2017 9:20pm
standupking36
thank you i'll have look Very Happy
Post #452789 2nd Oct 2017 9:32pm
kds2
You chaps (and chapeses just in case) are getting me worry`d now, I was hoping to keep the unit I have now and just swop it over, the after market radio I put in the p38 has an aux input so used that. Guess I will just have wait and see whats in the ffrr when I find it.
Post #452806 3rd Oct 2017 12:09am
TerryT-J
Wales 2005 Range Rover Vogue Td6 Java Black
This is what I fitted. Works OK for me and has AUX input.
http://www.fullfatrr.com/forum/topic43330.html
Post #452962 4th Oct 2017 3:33pm
