![]() | Home > Maintenance & Mods (L322) > Tdv8 sump plugs |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
some oil filters come with sump plugs, if yours doesn't then it would be worth getting two just in case one or both removed plugs are knackered..... ... - .- -.
Provarmint Member Since: 16 Aug 2017 Location: Warrington Posts: 76 ![]() ![]() ![]() |
I still don't understand why they are a throw away item, never replaced a sump plug on any other car. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1469 ![]() ![]() |
Its not the bolt, but the copper ring that fits around it making the seal between the bolt and the sump. They are supplied annealed ( softened ) so that when the bolt tightens, the copper deforms to match the shape of each surface. Copper like most metals / alloys work hardens ... so when you re-use the bolt *in theory* the copper ring will have hardened and not provide as good a seal .
The sump plugs that arrived don't have a metal washer, it has a rubber O ring fixed in the plug, I now understand why it is to be replaced. |
