![]() | Home > Maintenance & Mods (L322) > A sudden jolt/kick when you come to a standstill |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
The solenoid I think you're referring to is a gearbox one and will be contained within the valve body of the gearbox, I would strongly advise you to seek professional help i.e. gearbox specialist... It is a real minefield inside an auto gearbox, and without the necessary tools, computers, dynos, it is almost impossible to effect a repair. Yesterday I couldn't spell Engineer... Today I are one!
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 ![]() ![]() ![]() |
I went to the garage on Monday afternoon after receiving a call from them to say that their diagnostic machine had picked up low fuel pressure and that I required a new fuel pump. I took with me, 8 litres of Castrol Stop-Start 5W30 engine oil for them to complete the service and then discussed the problem of the car with the garage owner/mechanic. I mentioned that the recovery guy had found two fault codes; the low fuel pressure and 3-4 shift. According to feedback on another Range Rover forum the 3-4 shift fault code had pointed to a solenoid problem. He said that he had not run the diagnostics on the gearbox but only the engine. His thinking was that he would get the engine running properly first and would then see to any other problems. The recovery guy had also suggested that the 3-4 shift fault code might have been linked to the low fuel pressure because the gearbox might not have had enough power to change gear and that would have led to the "limited gears available" message. I had previously received a "transmission fault" message soon after buying the car and this had been sorted out when I upgraded the battery from a 100 amp battery to a 110 amp one. I am hoping that the replacement fuel pump might clear up the 3-4 shift fault code.
On Friday I went to the garage to pay my £584.83 bill which included £50 for diagnostics and £250 for labour and £97 for spark plugs (!!!). However, there is still a problem because the fuel gauge is showing empty despite being full to the brim. The garage claims that their mechanic is capable and blame a faulty fuel pump and the supplier of the part claims that it is not faulty and that he mechanic has upset electric in the fuel tank. They will not replace it unless they have it back for testing but that is impossible because if they remove it, i cannot drive my vehicle to return it. A catch 22 situation. However, the supplier would trust the opinion of the local Land Rover specialist and so I need to make an appointment with him. The rear view camera, which was working before I took it to the garage and that has worked once since returning from the garage, doesn't work now! They suggest that I have a loose connection but I think they must have snagged the wire when they removed the fuel tank and replaced it after fitting the new fuel pump. Anyway, another task for the specialist plus sorting out the parking sensors and recommending someone to replace the shift solenoid in the gearbox. I should have just gone to the specialist in the first place.
RuthlessGK Member Since: 28 Oct 2015 Location: Sheffield Posts: 83 ![]() ![]() ![]() |
You got any further updates pal?
DanPoole Member Since: 01 Mar 2017 Location: Kent Posts: 59 ![]() ![]() ![]() |
I appreciate this is an old post Steve, and you look to have moved onto another Range, but did you ever find a solution to this?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8345 ![]() ![]() ![]() |
You are best sending Steve a PM, he hasn't posted on here for 18months now... |
Hi Dan,
