![]() | Home > Maintenance & Mods (L322) > Split Charge Relay (VSR) with second battery |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Just found this:
So with my 2011 it's definitely going to need a battery-to-battery charger... Here's one I'm looking at, a lot dearer than a VSR: https://www.screwfix.com/p/ring-rscdc30-30...0wodMrgONA Thanks for all the replies too guys. Will continue a bit more research. Greg Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2550 ![]() ![]() ![]() |
A simple VSR works fine with my MY12. The above statement sounds like marketing hype for DC to DC chargers. |
Our vehicles sense the drain from the main battery via a sensor in the battery's negative to earth connection. An auxiliary battery that has its negative connected directly to earth is seen as a load by the logic controlling the alternator rather than a battery so keeps supplying power whilst the battery is using power (charging), just like idling with headlights, a/c, seat coolers switched on. If the auxiliary battery's negative was connected to the main battery's negative then the auxiliary battery would only be charged to LR's 80% charged design criteria for the main battery. |
....err not following you 100% but as per your earlier comment this is marketing hype and I can use a normal VSR? Cheers, Greg
My VSR is nothing special but gets the AGM aux battery back to fully-charged quite quickly.
Ok thanks Graeme, great to know.
Not unless the VSR specifically provides this feature, which some do until the auz battery voltage drops below the cut-out level. I may fit one of this type if mine dies although that compromises the ability to use the aux if the main is too flat to start the engine due to it already having been run down somewhat, but perhaps the aux would still have enough reserve to do the job.
