Home > Technical (L322) > Fault code P0480
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
Fault code P0480
I've just scanned my car for faults with my iid tool and this fault code comes up.PCM ENGINE TDV8 P0480-13 (2F) FAN 1 CONTROL CIRCUIT GENERAL ELECTRIC FAILURE. I have cleared the fault but it comes back when I rescan.I take it this refers to the cooling fan but the temperature doesn't go above average. Any ideas about this fault and should I investigate further?
Thanks 2009 Vogue SE Zermatt silver
Post #452201 27th Sep 2017 12:14am
kbald
Having a quick look on google it seems to be the cooling fan wiring or cooling fan relay. Have you tested the electric for the fan or the fuse as that would be the best place to start to make sure its all working. Current 2007 TDV8 Vogue Buckingham Blue
Post #452205 27th Sep 2017 6:49am
mrtidy
The strange thing is I didn't think fullfats had an electric fan I thought it had a viscous fan. Just done a search and it may be something to do with the heater fan or the final stage resistor. 2009 Vogue SE Zermatt silver
Post #452224 27th Sep 2017 11:01am
kbald
info from the workshop manual with some clues below.
P048013
Fan 1 Control Circuit
Cooling fan control circuit high resistance
Check the cooling fan and circuits. Refer to the electrical guides. Repair/renew as necessary. Clear the DTCs and test for normal operation. Current 2007 TDV8 Vogue Buckingham Blue
Post #452262 27th Sep 2017 5:06pm
fisha
My supercharged has a viscous fan and an electric one that sits in front of radiators. V8 or else ...
Post #452280 27th Sep 2017 6:17pm
mrtidy
I didn't know about an electric fan and a viscous fan.just thought my temp would have gone up. 2009 Vogue SE Zermatt silver
Post #452353 28th Sep 2017 1:43pm
bishbosh10
Diesels run very cool these days, especially in Manchester! Rolling with laughter Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #452386 28th Sep 2017 8:05pm
