![]() | Home > Technical (L322) > 2004 4.4 V8 Front air bag replacement-How to depressurise ? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1457 ![]() ![]() |
stab it. You're replacing it anyway ... |
Siclark Member Since: 05 Jun 2017 Location: Gloucestershire Posts: 40 ![]() ![]() ![]() |
You can't get to the air line connection on the top of the strut without dropping the strut down first. Can you remove the strut while it's still pressurised and then release the air from the air line connection or do you have to release the pressure first ? |
So the answer is yes you can remove the strut with it still pressurised. Lower it down enough to access the air line at the top of the strut, slowly undo the nut until air starts coming out slowly then wait for the strut to depressurise. |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 395 ![]() ![]() ![]() |
Another way is to gently undo the air line where it connects into the valve just behind the o/s front wheel arch liner. Current:
Well as I found out while doing this job, the later models don't have any valve behind the o/s wheel arch liner! |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Correct, I found that out too |
Ah....
Maybe that is done at the valve block by the tank. V8 or else ... |
Each corner still has it's own valve looking at the diagram and the front cross link valve operation is described below. The cross link valve was removed and replaced with a connector and so i imagine in the absence of the cross link valve the heights are just controlled by the ECU ?
Really ? Well I fitted Dunlop struts and every guide I read said to remove the new air line fittings from the struts and just screw in the originals still on the air line. They all said not to remove the old air line fittings from the air line unless they were leaking. |
This is the email reply from Island
I bought my Dunlop struts from LR Trade Parts and they came with no instructions for fitting at all. Every guide and video I looked at before doing the job said not to remove the original air line fittings from the air lines and to just screw them back into the new struts.
Maybe they are different now but I think mine were plastic or screwed into plastic and bonded in although cant remember for certain but I took them out of the new struts as I think I was intending to screw the old ones straight in but then decided to use the new ones and only one would tighten fully and one behaved a bit like it was stripped but remained air tight but when I questioned it I got the reply. This was about 4 years ago I think so memory a bit fuzzy. |
The new air line fittings on my Dunlop struts were white plastic with a brass nut on. They unscrewed really easily.
