![]() | Home > Maintenance & Mods (L322) > Tailgate not latching |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
This just started where the tailgate-metal not glass half- doesn't latch all the time. Need to close it 3 or 4 times. Adjustment , cleaning or it the actuator on the way out? Thanks. |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
I had this on mine, the plastic finger latches would stick and need manual release (ooooh errrr mrs).
Thanks guy. I had given it a bit of WD40 but will be more liberal and check alignment. |
It took several attempts with the WD40 for it to work. After a few weeks of manually wiggling the latches daily it is now back to normal. Tom
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I had to take mine apart, clean and lubricate as the WD40 wasn't getting to the sticky part very well but worked great after. |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
I had similar happen to mine, so I did all of the lubrication I could - didn’t work. I then took the panel off to see if a wire was loose etc - my problem was one of the two check straps had started to really rust through and deteriorate and was lying out of line and only slightly stopping the boot from shutting.
Thanks all. A little more WD 40 and it seems back to normal. Probably just crap in the mechanism. |
