Home > Technical (L322) > L322 2010 3.6 tdv8 front suspension/suspension fault
Kingsway2007
England 2011 Range Rover Vogue SE TDV8 Zermatt Silver
Hi guys/gals first post so please help!!
My front suspension is dropping when parked up after 1/2hr or so but only when the battery's connected! Disconnect the battery and it doesn't drop. No hissing or leaking airbags and new level sensor fitted on n/s/f. Suspension all fine and dandy when running/driving but suspension fault illuminated on dash. Been in 4x4 info screen and red flashing light on o/s/f wheel. 😩😩🙏🙏
Post #451321 18th Sep 2017 6:49pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
do you reset the with the steering wheel once battery is back on ?
Post #451337 18th Sep 2017 8:07pm
Kingsway2007
Yes from lock to lock do you mean? Re-connected battery and on its a@se this morning again but raised no problem! So battery connected it drops. Disconnected it stays up.
Post #451370 19th Sep 2017 6:53am
