![]() | Home > Maintenance & Mods (L322) > Transmission Mega Flush - Advice sought. |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
Driver Transmissions in Birmingham told me they would recommend a fluid change every 50,000 miles.
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 84 ![]() ![]() ![]() |
I'd love to get a definitive answer on this question - or at least a concensus!
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
After my original gearbox went bang at 137k the mechanic that rebuilds and installs auto boxes recommended changing the oil every 60k miles as a precautionary measure, even on the newer ones. He said it would show if something is starting to fail so it can be jumped on before complete failure.
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
I read the sealed for life was only sealed for the life of the warranty ?
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Yeah check my post on observations after transmission fluid change. I found an excellent YouTube video of an automatic transmission expert explaining why sometimes a very dirty transmission dies shortly after the full flush and fill. Basically he supports my theory that there is build up or sludge in places. When you do a full flush this new clean fluid allows the sludge to break off in large enough pieces to get into valve bodies and the such causing catastrophic failure. With a drain and fill the fluid is half dirty so how much particulates it can hold is less not allowing a rapid degunking of the sludge. Just a theory. I will be doing my 4th drain and fill, with filter and pentosin this time, in 30k miles. TC rumblings gone after 2nd drain and fill. I get the fluid for $10/liter so no big deal. Here is my post. http://www.fullfatrr.com/forum/topic32847.html |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
I had a new gearbox on 99k and since the new one change the fluid and filter every 40k drain and fill method |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 821 ![]() ![]() |
My regime is change fluid every 30 thou...change filter every 60
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Which part of PA? Im from Pgh area. Ive read up on this and you other post..looks like you have put a ton of time and effort and fluid into multiple drain/refills to fix your prob. I had on an off issues where the tranny will go into limited gears when in Auto mode....in sport mode it never happens. Been thinking about a flush....not sure if it would fix this though. 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
RRphil is the man when it comes to transmissions. I haven't put much money into the drain and fill with, will be, 2 filters. First one was OEM filter. I think it was over 4 liters for drain and filter but just under 4 liters without filter change. OEM filter and gasket was about $55. Fluid is about $10/liter. So about $100+$40+$40+(Febi filter and Pentosin)$70=$250. Compared to a new TC and/or transmission it's cheap.
