Home > Maintenance & Mods (L322) > gen LR ipod ACM fitting into an my05 questions
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
hi guys i believe im right in saying the above does fit and work ?
ive stripped down the dash and my questions were is the item in the pics the correct item that the kit plugs into i believe it is as the stereo wiring goes into it but just making sure
 onto no6 Range Rover
Everyone needs a hobby
Post #44333 3rd Jan 2011 4:38pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
You're right Mark. That's the correct unit. Thumbs Up
Post #44334 3rd Jan 2011 4:41pm
speedymarktd6
supurb ive ordered the kit , will pick it up in the week so thaught i would make a start on the job thank u Thumbs Up onto no6 Range Rover
Post #44335 3rd Jan 2011 4:54pm
SteveMFr
Site Sponsor
Exactly, as happy says.
So , how long to yank the dash? I've been saying it's quite doable in under an hour...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #44387 3rd Jan 2011 7:53pm
speedymarktd6
now that i know how too do it start to finish with fitting probably about hour and half ish its not a big nightmare that you imagine it to be Thumbs Up onto no6 Range Rover
Post #44751 5th Jan 2011 7:53pm
kil2508
Wales 2005 Range Rover Vogue Td6 Java Black
Hi mate
Sorry to hijack your post but been after the gen LR iPod kit for a while, but had no luck, do you have the part number/s please?
Also how much are they?
Gav
Post #45003 7th Jan 2011 6:37am
speedymarktd6
LR004806 @ about £300+ ish guy salmon LR in coventry 0844 470 7159 have 20 odd in stock Thumbs Up onto no6 Range Rover
Post #45123 7th Jan 2011 9:07pm
kil2508
Thank you! Thumbs Up
Post #45134 8th Jan 2011 6:55am
speedymarktd6
all fitted and fitted perfect so lets put this to bed that the kit WILL fit early facelift vehicles 05 -06 onto no6 Range Rover
Post #45255 9th Jan 2011 7:24pm
SteveMFr
Site Sponsor
There was a post on RR.net the other day where someone stated that aux-in (aside from the ipod) didn't work on pre07 vehicles. Was/is this a prob on your RR?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #45301 9th Jan 2011 9:28pm
ben2012
2005 Range Rover Vogue Td6 Buckingham Blue
Hi just wondering how the iPod integrates into the screen? Does it display any track info etc? Also where do u plug the iPod into?
Many thanks
Ben
Post #45484 10th Jan 2011 10:51pm
Stephen.125
@Steve, IIRC the AUX works with the red and white phono to 3.5mm mini jack with no issue. ditto the USB. I'll re-check when I get mine back at the end of the week.
@Ben, ID3 tag info is displayed as usual so track name and artists etc. The ACM as I think is previously stated emulates an MP3 CD changer (hence the ID3 tags) with the first 5 'discs' on the touch screen being the first 5 alphabetical playlists on the iPod or iPhone and the 6th 'disc' being everything on the device.
You can still access the repeat/random function and it will remember even with disconnecting the iPod/ignition off etc.
Generally the iPod is connected via a loose cable in the glove box though with careful preparation (and more dismantling) there may be enough cable to reach the centre console.
(Mine is an older iPod and usually is just left locked in the glove box so I didn't try this YMMV)
Steering wheel controls work ok and the sound quality is much much better than the 3.5mm mini jack AUX connection behind the centre console.
HTH
Steve
Post #45489 10th Jan 2011 11:03pm
Chemgopete
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Can you play video from the iphone if the ACM is fitted?
Post #46293 16th Jan 2011 9:55pm
Stephen.125
As I understand it. No. The only way I heard of is via the yellow, White and red Phonos with the official cable- and then only on the rear screens. AFAIK there is no way of getting iPod videos on the front screen.
Happy/intrigued to be proven wrong.
Post #46308 17th Jan 2011 12:09am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Am I reading this right, if I want to use my ipod in my 55 facelift then it will cost £300 for the parts and an hour and a half. letters not necessarily in the right order
Post #61375 24th Apr 2011 10:58am
