Home > Maintenance & Mods (L322) > A sudden jolt/kick when you come to a standstill
6029 king Stephen
United Kingdom 2008 Range Rover Vogue SE TDV8 Rimini Red
This is a bit difficult to describe but in my 2005 Supercharged Range Rover, I sometimes get a sudden jolt or kick when I have come to a standstill. It doesn't happen all the time but mostly when coming to a standstill from speed. Just as I come to a stop there is a jolt like someone has kicked you hard in the back. I have also noticed it when the car has been warm and we are in stop/go traffic. A similar thing happens when coming up to a roundabout and I have slowed almost to a standstill and decide to "go for it", there is a slipping sensation and the car doesn't move off but then suddenly does. The first time this happened, I aborted my attempt as there was a large lorry approaching!
I have read on here or somewhere else on the internet that this second problem might be linked to the front differential failing or about to fail. I have an oil leak on the front diff but don't know at this stage where it is leaking from. The jolt/kick feels like somebody is slamming the gearstick from 2nd into 1st. I have been told that the car has a misfire and that maybe after I have it serviced and the plugs replaced this might cure the latter problem but I wondered if all these things might be connected?
Grateful for any advice.
Regards,
Steve
Post #451295 18th Sep 2017 3:28pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
My supercharged does similar and I believe mine is gearbox related not the front diff.
How many miles has yours done? Mine is on 102,000 miles.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #451303 18th Sep 2017 5:07pm
Classic888
I had a similar issue with my 2007MY RR S/C last year. I changed the auto gearbox oil and filter. It sorted the problem out and I have covered about 9000 miles since. I would say that I did not have any mechanical noise only the jolt.
Post #451309 18th Sep 2017 5:59pm
Sandyt
Could well be the fluid thinning they drop into gear as you slow down so it could be a solenoid not working properly my guess is gearbox - mine does an odd jolt into 4th from top on kick down when the gearbox is really hot same thing I think
Post #451310 18th Sep 2017 6:03pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
+ 1
Does it occasionally when hot when slowing down, feels like a slight push in the back with no mechanical noise, car is on 52k.
Post #451319 18th Sep 2017 7:45pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
sounds like driveline shunt , common on many auto boxed motors , try oil and filter first as suggested , cheapest thing to try
Post #451344 18th Sep 2017 9:14pm
6029 king Stephen
Thanks for all replies. I will try oil change and filter as suggested. Mine has done 126,000 miles.
Regards,
Steve
Post #451363 19th Sep 2017 5:40am
zarnd
I had an oil leak form the gearbox so had gearbox oil flushed and changed but still there so think mine is a solenoid issue or mechanical issue that can be driven around and just living with it for the moment as not getting any worse.
cheers and good luck Alex
2007 M5 Touring
2004 SL55 AMG
Post #451380 19th Sep 2017 10:15am
miggit
I had a similar thing in my TD6, the pressure actuator solenoid on 1-2 was on it's last legs and I also had a lot of play in the splines on the front propshaft / diff coupling. The problem improved when the diff coupling was changed, but it never actually went away, and it still gave a donk as it changed down to 1st when slowing up gently.... Strangely in never did it if you stood of the stop pedal, only if you took things easy... which would drive you nuts in a traffic jam moving at 15 mph, I used to lock it in 1st Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #451383 19th Sep 2017 10:45am
alistairh
I had the excact the same symptoms for months until my diff failed on Saturday pulling away from a set of lights..does your slightly thump when you select drive or reverse? Mines did this also...
Post #451401 19th Sep 2017 1:07pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Change oil and filter,but you MUST also have the adaptive values reset.That takes up all the wear in the clutches in the box.My box did the same and a double flush,filter and reset did the trick Very Happy 2012 TDV8 Vogue SE 4.4
Post #451416 19th Sep 2017 3:45pm
standupking36
how would you reset the values?
Post #451434 19th Sep 2017 8:32pm
holidaychicken
Wasn't there a firmware update that could be applied?
This might help
http://www.4x4brasil.com.br/forum/attachme...guide-.pdf
Post #451436 19th Sep 2017 8:36pm
Frans@Yamorna
On the ZF box it can be done with a MSV2 tool.Not sure if it can be done with the GAP tool.It can be done manually as well,do a search on the D3 forum,it is there.Sorry that I can not be more spesific.
Hope you get sorted. 2012 TDV8 Vogue SE 4.4
Post #451440 19th Sep 2017 9:04pm
6029 king Stephen
Mine doesn't thump when selecting D or R, in fact the gear selection is very smooth. What is most irritating about this jolt is that it doesn't happen all the time and sometimes it doesn't do it at all but when it does, it is really annoying. I tis irritating because if it happened all the time, it would be easier to diagnose. When I have washed it at the car wash and included a underbody wash and wax as part of the programme, it doesn't do the jolt for some time after. When I first did this, I though I had cured it but a day or two later, it reminded me that it was still there.
I am booking the car in for a service at the end of next week and will add new oil and filter for the gearbox to the service. If I am lucky, that might be the end of the problem....
Regards,
Steve
Post #451599 21st Sep 2017 12:44pm
