Home > Technical (L322) > How does the L322 know when it is grounded? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Gents have been looking through the workshop manual to find out which sensor and where it is situated gives the information to the ecu that the car is grounded and so sends it to extended mode and can't find anything anyone any ideas\
16th Sep 2017 12:37pm |
From memory think on the p38 there was a sensor on the front wishbone?? |
16th Sep 2017 12:38pm |
Yes think you are right from what I have read which doesn't help me afraid but still good to know |
16th Sep 2017 3:30pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Super extended mode is activated by the driver whilst in extended mode by holding the brake pedal pressed then pressing the raise switch. |
16th Sep 2017 9:20pm |
Yes thanks it is just that mine goes into extended when I push for it to go into access mode |
17th Sep 2017 7:10am |
SteMY06HSE Member Since: 23 Jun 2016 Location: Doha Posts: 63 |
Hi Sandyt, mine used to do that as well and regularly give me suspension fault messages. I am currently under test to cure it which so far is going well.
17th Sep 2017 8:07am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
I believe there is also a "knock" sensor, so if your underbody hits something the suspension reacts. .
17th Sep 2017 8:46am |
No knock sensor for the suspension which wouldn't be of any use on loose gravel roads anyway. The static height sensor signals when the vehicle is meant to be changing height is the indicator. |
17th Sep 2017 12:37pm |
Having posted I then searched the wiring diagrams but couldn't find one
17th Sep 2017 5:02pm |
Well going to work through it tomorrow and see what I find but as my poor old bus is 10 yrs old and nearly 150k on the clock may just replace the back bags (fronts done a couple of years ago and a new pump AMK ) and replace all 4 height sensors
17th Sep 2017 8:26pm |
