![]() | Home > Maintenance & Mods (L322) > Roof rack help for L322 |
stu_007 Member Since: 25 Jun 2016 Location: Cardiff Posts: 177 ![]() ![]() |
This is G4 one without floor and would think you'd need a floor built so roof could take weight of tent?:
Clive603 Member Since: 21 Jun 2016 Location: Sussex Posts: 35 ![]() ![]() ![]() |
Her Ladyship reckoned the standard longitudinal roof rails and key operated cross rails are fine for her Howling Wolf roof tent on her 2003 TD6. I got her another pair of cross rails and advised that the necessary spacers be made for front and rear rails to compensate for roof curvature so that four cross rails could be used but apparently the folk who fitted it didn't agree so it was only fitted on two. Hung on fine at Miss Leadfoots normal rate of progress.
SamUK Member Since: 29 Jun 2017 Location: South Posts: 32 ![]() ![]() ![]() |
Thanks for the replies so far guys. I had looked at the cross rail options, after a few google searches it seems quite a few folks out there use them with roof tents and big roof boxes with no problems.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1547 ![]() ![]() |
Three Rhino Rack heavy duty cross bars together with the appropriate feet.
Do you have a link to the rhino rack brand? |
http://www.rhinorack.co.uk/Vehicle_LAND%20..._4101.aspx Ron B. VK2OTC
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
How handy are you Sam? |
I can put my hands to most things, roof racks on the other hand aren't as simple as you'd think tonmake lol |
So after endless roofrack/roof bar searching I've noticed some roof bars come as a kit with longitudinals that go over the 3 rack mounts on either side of the roof. Are these necessary or just a sales gimmick to bump the price up? |
Sam, most commercial roof rack required you to remove (cut off) plastic flip cover. on my i made a chanel so thy stay, you just open them.
^ Interestingly I have been thinking of making a set of roof bars along similar lines, but using hardwood blocks to make the mounting blocks. You have even used dome nuts on the threaded rod used to hold everything in place as per my sketches.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I really want a roof tent but wouldn't want to snap the covers off the fitting holes on the roof.
One doesn't need to snap off the covers with the Rhino Rack - my covers are still there. Ron B. VK2OTC
nicedayforit,
