Home > Technical (L322) > H7 advice please
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
H7 advice please
Looking to change my H7s ( 2007 VSE ) with adaptive headlights, would anyone know if these
H7 200W 20000LM LED Headlight Conversion Kit Car Beam Bulbs Driving Lamps White ebay no eBay Item No. 172803296704
Would fit please ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #451040 15th Sep 2017 8:25pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Are they not xenons already fitted?
Post #451050 15th Sep 2017 9:45pm
dolph34
I jave the night breakers fitted but thought these might be better if they fitted 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #451051 15th Sep 2017 9:46pm
there's a large heat sink on the back of these so they 'might' not fit in the headlight unit...i'd check the measurements... ... - .- -.
Post #451068 16th Sep 2017 8:03am
I've got a set of those h7 led bulbs to go in my high beam lights. I've tried twice to fit them without success. The spring that holds the bulb into the light fitting is almost impossible to refit with the led bulbs in situ, mainly due to the limited space available at the rear of the headlight. I have reluctantly come to the conclusion that they are impossible to fit without removing the headlight from the car.
I have been considering fitting the bulbs by discarding the springs and instead holding them in place with thin copper wire but not totally sold on the idea.
The one thing I have found is they are not plug and play, they are Censored difficult to fit. Thumbs Up
In addition if you do manage to fit them I doubt the removable plastic cover on the rear of the headlight could be refitted.
Post #451074 16th Sep 2017 9:05am
dolph34
Thanks gents , i appreciate the thoughts and advice, i will pass and look for more standard fitment LEDS 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #451079 16th Sep 2017 9:36am
RaveRover
Australia 2005 Range Rover HSE 4.4 V8 Java Black
Hey. Do you still get the 'test pulse' in the headlights if your running LED's??
I had to fit an inline resistor box to my 05' L322 when towing my camper or box with LED's fitted otherwise (even with the ignition off) i'd get a rhythmic flash coming thru to the trailer. Very annoying.
Just wondering if the same happens with the headlights..Cos Id like to go LED. Just cut a neat round hole in the cover to accomodate the heat sink.
Thanx Matt.
Post #481579 21st Jun 2018 10:20pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
They are the same style as I have fitted. They fit with plenty of room fot the covrr to go back on.
You will have to remove the headlight unit from the car and whlist it is fiddly it isnt difficult.
I posted up about this a while back.
I will see if I can find it 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #481582 22nd Jun 2018 12:10am
I have this type/style fitted in my high beams and they are incredibly good sir Thumbs Up
https://www.ebay.co.uk/itm/H7-Led-Car-Head...Sw3Bla1-I6
Post #481585 22nd Jun 2018 12:33am
just to clarify, the 2002-2009 FF's headlights are easily taken out to fit the bulbs but the 2010-2012 headlights need the bumper to be taken off to get the headlights out.... ... - .- -.
Post #481594 22nd Jun 2018 8:22am
Crispian22
Have these on mine,they're great👍
As Stan said,easier to take headlamp out to fit,2 minute job👌
Post #481601 22nd Jun 2018 10:09am
