![]() | Home > Technical (L322) > The devil has taken over my RR TD8 2007 |
jfarrell32 Member Since: 23 Sep 2014 Location: Straffan Posts: 25 ![]() ![]() |
Tonight as we prepared to go to bed the devil seems to have taken over our RR. The horn started blaring and no matter what I did it continued intermittently. I tried spraying wd40 on the door locks and bonnet latch in case there was a sensor somewhere but with no success. Eventually I disconnected the battery and am now going to bed. Any thoughts or suggestions on the source of the issue would be very helpful. Crazy machine....... |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1461 ![]() ![]() ![]() |
buy some ear plugs, i suspect it was getting cold and lonely |
no! I tried turning on/off, short driving, open and closed all doors and bonnet. Eventually disconnected battery....... |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 504 ![]() ![]() ![]() |
The same thing happened to me after the AA man changed my battery, when we were manhandling the bonnet
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
+1 for the bonnet switch, mine on the disco was playing up a couple of weeks ago, kept setting the alarm off! There is nothing that can't be fixed with a hammer😜😜
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
If not the bonnet sensor, try locking the car with a double press, to deactivate internal sensors.
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
^+1
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I also vote bonnet switch. In my case the plastic bracket holding the switch had cracked which allowed the switch to drop and simulate the bonnet being open. ______________________________
Guy in the local garage fixed it - I was told bonnet sensor but now the horn does not work. Why would disconnecting the bonnet sensor stop the horn from working? |
Had a look at the wiring diagrams for '02 - '05 (so might be different on your later model), the horns and the alarm system do not appear to be connected in any way.
