Home > Technical (L322) > handbrake Q
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
handbrake Q
the handbrake is inboard and mine rubbish , is it likely to be the usual stretched cable or worn out rear shoes , car has had recent discs and pads all round so I suspect they forgot to adjust the rear shoes when rebuilding them
simon
Post #450632 11th Sep 2017 10:09pm
Probably the automatic adjusters, they let them off to fit the disc then pulling the handbrake should wind them in but I doubt yours will be, they seize up.... Could also be a rusty backplate, the shoes fix to the backplate and these rust out and allow the shoes to move instead of pressing inside the disc....
Cables are usually OK so get the rear discs off and have a look... Thumbs Up Pete
Post #450642 11th Sep 2017 10:36pm
bembo449
I reckon that's whats happened pal , the running gear is in really good condition , no real corrosion of any sort , I had the ruddy wheels off earlier to do the height sensors ! doh ! have these got the hole to adjust them threw ??
Post #450644 11th Sep 2017 10:43pm
I can't remember, should say in RAVE which you can download from the WIKI...
The shoes don't last long and the springs have a habit of weakening as well, I changed the entire lot on my last fatty and the handbrake was still rubbish, I never used it anyway, stick it in Park and it's not going anywhere...!!! Thumbs Up Pete
Post #450648 11th Sep 2017 10:50pm
bembo449
ha ha , ok pal , I use mine as I leave work , just to shut the gates behind me
Post #450753 12th Sep 2017 9:38pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
there is an adjustment hole
Post #450809 13th Sep 2017 1:07pm
bembo449
cool , that's what I was hoping pal
Post #450873 13th Sep 2017 9:59pm
