![]() | Home > Maintenance & Mods (L322) > Split Charge Relay (VSR) with second battery |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Hello chaps,
...just found this:
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I have a dual battery setup with a similar VSR. Connections are protected with a 100amp circuit breaker. Like a lot of us in Australia when out in the bush camping I use a 220w solar panel through a voltage controller to keep the second battery charged, mine is used to run a fridge freezer. I would not be happy to start the car from the second battery using the existing cable to the rear. It does not look meaty enough to me, it might be OK but why risk it. Just move the second battery to the front and use jumper cables in the unlikely case of the main failing to start the car. 2007 TDV8 VSE
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 ![]() ![]() ![]() |
Graeme, I need a new second battery for my car - the two small, in line, rear batteries (2) were fitted in the rear floor by ULR Land Rover when the car was new in June 2012. There is a Redarc isolator also fitted.
I have an Oddessy Extreme pc1700 in mine. Fits in the rear with no problems.
You could of course do it the simple way. Install a 110AH battery in the rear connected to the protected 100A cable at the rear fuseboard. Connect the battery earth locally through a manual means of isolation and fit an isolator to the vehicle battery earth. I have this arrangement and never had a problem. If you wish to run a load on the second battery such that it might discharge it simply isolate the vehicle battery manually first. You then always have the vehicle battery to start the car whatever the condition of the second rear battery.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2660 ![]() ![]() |
Chris, I had to cut out a section of the plastic bracket to fit a Remco RM-12DC (the deep cycle version, not dual purpose). I'll track down some pictures that I took at the time.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
this is a mod I'd really like to do on my Mercedes , the previous model had a split double battery set up , my model has just the one and its doesn't like being left for more than a week without being used , the year model after mine went back to the twin setup so Mercedes clearly realised the car needed the extra that another battery brings , so I think I will have a read and see if I can adapt what you guys have done to it
Thanks Graeme! 2017 Range Rover Vogue SE SDV8 (with e-diff)
The only picture that I can find...
Thanks for the pic Graeme, looks nice.
The voltage sensitive relay only connects the aux battery whilst the main battery voltage is high enough then disconnects at a slightly lower voltage that in practice occurs within a short while after the ignition is switched off.
Ok thanks Graeme. Just trying to get up to speed on this stuff...
The VSR effectively isolates the 2nd battery once the engine is turned off. I have rewired the accessory plug in the rear loadspace directly to the second battery so I plug my fridge into that socket. When I am set up camping I connect up a solar panel via Anderson plugs to keep the 2nd battery charged. I have never had the 2nd battery go flat.
