![]() | Home > In Car Electronics (L322) > Denso touch screen issue please help |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
You may need to check the mmm firmware on the secret code screen, 1030 or above.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
After speaking with Pat at Gap Diagnotics recently due to an error code relating to a module reflash over a series of 3 days and a number of emails and even a reflash of the ACM module I still have the problem we have tried everything but the electrical gremlin stills exists but upon seeing that another member had a very similar issue and he replaced the headunit touchscreen to eradicate it. So here goes I will purchase a touchscreen fingers crossed this sorts the issue! 👍😜 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Thanks for all the help guys it turned out I had a faulty touch screen headunit came today fitted this evening all good 👍 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
