![]() | Home > In Car Electronics (L322) > Instrument cluster |
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 ![]() ![]() ![]() |
I just had mine done and I watched the guy do it he broke off several clips on the back with pliers in order to get it open. |
Gold Ranger Member Since: 31 Mar 2017 Location: East Midlands Posts: 33 ![]() ![]() ![]() |
try straightening the black lugs straight and then the cluster should pull apart |
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 ![]() ![]() ![]() |
Hello, well i managed to get it apart withut breaking anything off but i now find i have the bonded tape on the ff.i had bought the non bond and so i am not sure if this will work. I cantget thetape to stick and when i try to assemble it the tapejust falls out. Is there a special glue to use or am i up thecreek without a paddle ? |
make sure you get rid of any old glue on the circuit board - i used cotton buds and nail varnish remover on mine - you need the contacts to be nice and shiny
Thanks for that i will give that a try, the videos i watched just stuck it down so i thought there must be some trick i was missing. |
Well its done but not perfect, but better, now this has raised another issue, i have had the suspension inactive issue for a while and have tried a number of remedies, this was partly why i attempted to do the pixels so that i could read what my iid tool was showing. Befor doing the pixel the suspension error used to clear after standing a while, an hour or two, then it would only show after traveling about 5 mins. Now after removing and refitting the instrument cluster the inactive suspension will not clear even using the iid tool, i did the hard reset disconnecting the battery, no change.any ideas? |
have you done the steering wheel reset?
Done that |
I had that on mine but I drove round my paddock 360 degrees on full lock cleared and has not come back again. When I had my cluster repaired it reset everything on the main computer for some reason. |
Richy Member Since: 12 Sep 2017 Location: Tyne and Wear Posts: 1 ![]() ![]() ![]() |
Just got mine back today after I was too scared to do it myself!
