Home > Technical (L322) > Flat battery but never seen this before.. |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I parked up tonight and switched the car off. I got out to unload the boot and then went in the house, leaving the key in the ignition (position 1). Only just realised what I’d done and went outside to retrieve the key and the dash lights are all flickering rapidly. The battery is dead flat now but I’ve never seen the lights flicker like this.
7th Sep 2017 10:40pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2266 |
They do do odd things if the battery is weak do you have a fault reader? How old is the battery? and how often is the fatty used? |
8th Sep 2017 6:00am |
It’s used every day. Battery is about 2 years old. I’ll get it jump started today and see what faults I have. I disconnected the battery overnight |
8th Sep 2017 6:30am |
Thats all I can suggest it would be different if it was used every now and then - I used mine every day for 3 years never a problem then started to use it once or twice a week and got all sorts of daft faults
8th Sep 2017 6:47am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35373 |
the td6 takes a lot of power to get going so i reckon its the battery that needs replacing.. ... - .- -.
8th Sep 2017 7:01am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I've been working on a 2006 TD6 which has been standing immobilised for months and i charged the battery but again left it for a week with a lot of sitting in it not started and running diagnostics.
8th Sep 2017 6:31pm |
